the workspace by default.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
for GNAT. It was the number of Ada tasks when in fact the run-time
only required a single key.
Also added the CONFIGURE_MAXIMUM_FAKE_ADA_TASKS constant to account
for resources allocated for each non-Ada task/thread which invokes
the Ada run-time implicitly through an Ada call.
to lib/include.
be resolved.
RTEMS initialization tasks.
only the rtems api don't have to include it.
in each thread which must be set when the post switch extension is to be run.
like signal dispatching.
+ variable length messages
+ named devices
+ debug monitor
