* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | updated version to 4.0.0 | Joel Sherrill | 1997-03-08 | 1 | -1/+1 |
* | changed version string to 3.6.0 | Joel Sherrill | 1996-09-30 | 1 | -1/+1 |
* | changed version | Joel Sherrill | 1996-07-03 | 1 | -1/+1 |
* | changed version to 3.5.17 | Joel Sherrill | 1996-05-24 | 1 | -1/+1 |
* | Updated version to 3.5.15. | Joel Sherrill | 1996-05-02 | 1 | -1/+1 |
* | changed version number to 3.5.14 | Joel Sherrill | 1996-04-24 | 1 | -1/+1 |
* | changed version to 3.5.1 | Joel Sherrill | 1996-01-19 | 1 | -1/+1 |
* | changed version | Joel Sherrill | 1995-12-08 | 1 | -1/+1 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 1 | -2/+2 |
* | moving files around and adding the exec/wrapup directory | Joel Sherrill | 1995-09-22 | 1 | -1/+1 |
* | Changed version number | Joel Sherrill | 1995-09-20 | 1 | -1/+1 |
* | The word "RTEMS" almost completely removed from the core. | Joel Sherrill | 1995-09-11 | 1 | -1/+21 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API. | ||||
* | Numerous miscellaneous features incorporated from Tony Bennett | Joel Sherrill | 1995-08-17 | 1 | -15/+17 |
| | | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables | ||||
* | no limit removed | Joel Sherrill | 1995-08-17 | 1 | -1/+1 |
* | final 3.2.1 Module file and version updates | Joel Sherrill | 1995-08-15 | 1 | -1/+1 |
* | after testing go32 and cvme961 | Joel Sherrill | 1995-07-21 | 1 | -1/+1 |
* | Ada95, gnat, go32 | Joel Sherrill | 1995-07-12 | 1 | -1/+1 |
* | changed release number to 3.2.0 | Joel Sherrill | 1995-06-04 | 1 | -1/+1 |
* | Fully tested on all in-house targets | Joel Sherrill | 1995-05-24 | 1 | -1/+1 |
* | Initial revision | Joel Sherrill | 1995-05-11 | 1 | -0/+140 |
