path: root/c/src/exec/sapi/include/rtems/extension.h (follow)
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-5/+24
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-2/+3
* Initial revisionJoel Sherrill1995-05-111-0/+169
