* | Make sure pthread init stack size is always set. | Joel Sherrill | 1999-07-09 | 1 | -0/+5 |
* | Moved definitions to a more logical place. | Joel Sherrill | 1999-07-08 | 1 | -4/+4 |
* | Patch from Jiri Gaisler <jgais@ws.estec.esa.nl> to allow stacksize | Joel Sherrill | 1999-05-07 | 1 | -2/+8 |
| | | | | of POSIX Init thread to be user configured. | ||||
* | POSIX Timers submitted by Juan Zamorano Flores | Joel Sherrill | 1999-02-03 | 1 | -0/+9 |
| | | | | <jzamora@avellano.datsi.fi.upm.es>. | ||||
* | Moved stackchk.h to rtems subdirectory. | Joel Sherrill | 1998-12-03 | 1 | -1/+1 |
* | Corrected interrupt stack allocation. | Joel Sherrill | 1998-05-27 | 1 | -3/+7 |
* | Include memory for Ada task stacks. | Joel Sherrill | 1998-05-18 | 1 | -2/+2 |
* | Added default value for CONFIGURE_MAXIMUM_POSIX_THREADS since it is | Joel Sherrill | 1998-05-04 | 1 | -0/+1 |
| | | | | | used to calculate the amount of memory used by tasks whether the POSIX API is enabled or disabled. | ||||
* | Removed redundant "* 1024" which exploded the size of the workspace. | Joel Sherrill | 1998-04-30 | 1 | -2/+2 |
* | Added numerous entries to make the memory calculation more accurate: | Joel Sherrill | 1998-04-27 | 1 | -1/+67 |
| | | | | | | | | | | | | | + POSIX threads + Ada tasks + POSIX threads API support + POSIX condition variables + POSIX keys (still do not account for data fields) + POSIX mutexes + POSIX queued signals + added macro for extra memory for task stacks + default value for CONFIGURE_MAXIMUM_FAKE_ADA_TASKS + extra memory for Ada task stacks | ||||
* | Changed to account for libio's maximum_semaphores as well as its | Joel Sherrill | 1998-04-18 | 1 | -1/+5 |
| | | | | | | memory requirements. Also added variable to tell libio how many file descriptors to allocate. | ||||
* | Numerous changes which in total greatly reduced the amount of source | Joel Sherrill | 1998-04-15 | 1 | -1/+9 |
| | | | | | | | | | | | | code in each BSP's bspstart.c. These changes were: + confdefs.h now knows libio's semaphore requirements + shared/main.c now copies Configuration to BSP_Configuration + shared/main.c fills in the Cpu_table with default values This removed the need for rtems_libio_config() and the constant BSP_LIBIO_MAX_FDS in every BSP. Plus now the maximum number of open files can now be set on the gcc command line. | ||||
* | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1998-04-15 | 1 | -3/+25 |
| | | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | ||||
* | Account for interrupt stack space | Joel Sherrill | 1998-04-14 | 1 | -1/+12 |
* | Added stack checker extension | Joel Sherrill | 1998-04-14 | 1 | -2/+14 |
* | Now accounts for region used by RTEMS malloc and extension used | Joel Sherrill | 1998-04-14 | 1 | -4/+16 |
| | | | | by newlib. | ||||
* | Added misisng line continuation. | Joel Sherrill | 1998-02-20 | 1 | -1/+1 |
* | Accounted for fixed system overhead. | Joel Sherrill | 1998-02-19 | 1 | -2/+10 |
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Patch from Ralf Corsepius to reduce the amount of memory consumed by | Joel Sherrill | 1998-02-04 | 1 | -2/+6 |
| | | | | the workspace by default. | ||||
* | Added CONFIGURE_GNAT_KEYS to correct the number of keys configured | Joel Sherrill | 1997-12-23 | 1 | -12/+11 |
| | | | | | | | | | for GNAT. It was the number of Ada tasks when in fact the run-time only required a single key. Also added the CONFIGURE_MAXIMUM_FAKE_ADA_TASKS constant to account for resources allocated for each non-Ada task/thread which invokes the Ada run-time implicitly through an Ada call. | ||||
* | Added CONFIGURE_MEMORY_USER_OVERHEAD constant per Chris Johns request. | Joel Sherrill | 1997-11-18 | 1 | -1/+6 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | Added GNAT configuration parameters. | Joel Sherrill | 1997-08-04 | 1 | -4/+19 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | added posix configuration parameter maximum_queued_signals. | Joel Sherrill | 1996-06-13 | 1 | -0/+5 |
* | tests now specify whether using posix initialization threads table | Joel Sherrill | 1996-05-29 | 1 | -13/+45 |
| | | | | or rtems initialization table in configuration table | ||||
* | fixed support for posix initialization threads table | Joel Sherrill | 1996-05-29 | 1 | -2/+22 |
* | Addressed RTEMS API initialization tasks table in a system without | Joel Sherrill | 1996-05-29 | 1 | -3/+7 |
| | | | | RTEMS initialization tasks. | ||||
* | added maximum keys | Joel Sherrill | 1996-05-28 | 1 | -1/+1 |
* | added ifndef's for the POSIX maximum field in the POSIX api configuration table | Joel Sherrill | 1996-05-28 | 1 | -1/+6 |
* | made posix configuration information conditional so configurations wanting | Joel Sherrill | 1996-05-28 | 1 | -1/+38 |
| | | | | only the rtems api don't have to include it. | ||||
* | added initial posix configuration support | Joel Sherrill | 1996-05-28 | 1 | -9/+14 |
* | Minor bug fixes to get all targets compilable and running. The | Joel Sherrill | 1995-09-19 | 1 | -4/+99 |
| | | | | | | single biggest changes were the expansion of the workspace size macro to include other types of objects and the increase in the minimum stack size for most CPUs. | ||||
* | Added... This is the Configuration Tables Template file. | Joel Sherrill | 1995-09-11 | 1 | -0/+282 |
