path: root/c/src/exec/sapi/headers/io.h (follow)
* split the inclusion of "EXTERN" data based on whether it was sapi,Joel Sherrill1996-05-281-4/+4
| | | | score, rtems api, or posix api related.
* changed io manager initialization routine to not be staticJoel Sherrill1996-02-211-3/+1
* typos fixedJoel Sherrill1995-10-311-11/+11
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-12/+44
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-171-44/+54
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* Fully tested on all in-house targetsJoel Sherrill1995-05-241-3/+3
* Initial revisionJoel Sherrill1995-05-111-0/+204
