path: root/c/src/exec/rtems (unfollow)
2002-04-082001-04-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+5
* src/tasks.c: Pre-initialized switch extension for list.
* macros/rtems/score/timer.inl: Corrected typo on end of line.
2002-04-082002-04-08 Chris Johns <ccj@acm.org>Joel Sherrill2-0/+6
* Per PR142, make task switch extension its own list. * src/tasks.c (_RTEMS_tasks_User_extensions): Reflect above.
2002-04-022001-03-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-9/+14
* Per PR126, configuration structures now match docs. * include/rtems/rtems/config.h: Use public data types.
2002-03-292001-03-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill6-77/+73
* Per PR147 addressed problems when reseting and inserting a timer into a timer chain that did not honor time passage since the last time the timer server was scheduled and the new insertion. * include/rtems/rtems/timer.h, src/timerreset.c, src/timerserver.c, src/timerserverfireafter.c, src/timerserverfirewhen.c: Broke up the "reset server" routine into a set of very specific routines that allowed the server to be unscheduled, timer chains to be "synchronized" with the current time before inserting a new timer.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill6-5/+8
* Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * inline/Makefile.am: Remove AUTOMAKE_OPTIONS. * macros/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-02-012001-01-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+26
* include/rtems/rtems/timer.h: Missed merging these modifications in previous merge of new timer functionality.
2002-01-292001-01-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill4-50/+184
* Fixed bug where resetting a timer that was not at the head of one of the task timer chains resulted in the Timer Server task waking up too far in the future. * Added rtems_timer_get_information() directive to support testing. * src/timerserver.c, include/rtems/rtems/timer.h, * src/timergetinfo.c: New file. * src/Makefile.am: Modified to reflect above.
2002-01-222001-01-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-19/+41
* include/rtems/rtems/timer.h, src/timerserver.c: Add priority argument to rtems_timer_initiate_server().
2002-01-182001-01-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+9
* include/rtems/system.h: Only include cpuopts.h when building a multilib configuration. Some ports still need targopts.h but this small modification lets those ports work non-multilib while fixing being fixed for multilib.
2002-01-162001-01-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-0/+454
* Added task-based timers to the Timer Manager. This added three new directives: - rtems_timer_initiate_server - rtems_timer_server_fire_after - rtems_timer_server_fire_when In the process of doing this, a number of cleanups were made. * src/timerserver.c, src/timerserverfireafter.c, src/timerserverfirewhen.c: New files. * include/timer/timer.h: Added new prototypes and supporting types. * inline/rtems/rtems/timer.h, macros/rtems/rtems/timer.h: Enhanced _Timer_Is_interval_class() to cover the class TIMER_INTERVAL_ON_TASK. * src/Makefile.am: Accounted for new files. * src/rtemstimer.c: Added initialization of _Timer_Server variable. * src/timercancel.c, src/timerreset.c: Account for addition of timer classes. Also corrected the headers. * src/timercreate.c, src/timerdelete.c, src/timerfireafter.c, src/timerfireafter.c, src/timerident.c: Corrected header.
2002-01-162001-01-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill13-41/+203
2002-01-162001-01-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-2/+8
* src/taskmode.c: Ensure the this service does not dispatch before tasking is enabled at initialization time.
2002-01-072002-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill13-1197/+8
* optman/, optman/.cvsignore, optman/Makefile.am, optman/no-dpmem.c, optman/no-event.c, optman/no-mp.c, optman/no-msg.c, optman/no-part.c, optman/no-region.c, optman/no-rtmon.c, optman/no-sem.c, optman/no-signal.c, optman/no-timer.c: Removed entire contents of optman/ directory since it has been moved.
2002-01-042001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
* configure.ac: Use AS_IF instead of if/then/else. Add AC_DEFINE_UNQUOTED(RTEMS_UNIX) for RTEMS_CPU==unix. Add AC_DEFINE_UNQUOTED(RTEMS_UNIXLIB) for RTEMS_CPU==unix. Add include/Makefile to CONFIG_FILES. Add AC_ENABLE_MULITLIB. Remove wrapup/rtems, wrapup/itron, wrapup/posix. Remove */optman/Makefile from CONFIG_FILES. * Makefile.am: Add include to SUBDIRS. * rtems/Makefile.am: Remove optman from SUBDIRS. * sapi/Makefile.am: Remove optman from SUBDIRS. * include/Makefile.am: New file. * include/rtems/bspIo.h: Relocated from lib/include. * include/rtems/libio_.h: Relocated from lib/include.
2001-12-192001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill3-4/+9
* src/Makefile.am: Add multilib support. * optman/Makefile.am: Add multilib support.
2001-10-232001-10-23 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-2/+6
* macros/rtems/rtems/asr.nil: Fixed typo.
2001-10-232001-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2-1/+6
* macros/Makefile.am: Replace INLINES w/ MACROS (Fix stupid typo in previous patch).
2001-10-162001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill11-135/+89
* include/rtems/Makefile.am: Remove. * include/rtems/rtems/Makefile.am: Remove. * include/Makefile.am: Handle subdirs, require automake-1.5. * inline/rtems/Makefile.am: Remove. * inline/rtems/rtems/Makefile.am: Remove. * inline/Makefile.am: Handle subdirs, require automake-1.5. * macros/rtems/Makefile.am: Remove. * macros/rtems/rtems/Makefile.am: Remove. * macros: Handle subdirs, require automake-1.5. * Makefile.am: require automake-1.5.
2001-09-282001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill5-4/+11
* include/rtems/rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * include/Makefile.am: Use 'PREINSTALL_FILES ='. * inline/rtems/rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * macros/rtems/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
2001-09-212001-09-14 Fernando Ruiz <fernando.ruiz@ctv.es>Joel Sherrill2-1/+5
* src/tasks.c: Dereference pointer passed to destructor.
2001-08-302001-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+6
* inline/rtems/rtems/attr.inl: Correct typo and use correct attribute RTEMS_SYSTEM_TASK. Reported by Chris Johns <ccj@acm.org>.
2001-08-162001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+6
* src/msgqsubmit.c: Add a comment indicating that we do not have to account for possibly blocking during the core send operation because Classic API message queue send is always non-blocking.
2001-08-092001-08-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-5/+12
* src/msgqsubmit.c: Unblocking message queue operations should NOT use _Thread_Executing for return status since it is permissible to invoke message send operations from an ISR. This was reported by Suvrat Gupta <suvrat@utstar.com>.
2001-03-292001-03-26 Zoltan Kocsi <zoltan@bendor.com.au>Joel Sherrill2-0/+8
* src/eventsurrender.c: Clear event condition when task is unblocked. This makes sure that subsequent event send thinks the task is still blocked and overwrites the initial events received.
2001-02-052001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill6-17/+27
* include/Makefile.am, include/rtems/rtems/Makefile.am, inline/rtems/rtems/Makefile.am, macros/rtems/rtems/Makefile.am, rtems/optman/Makefile.am: Apply include_*HEADERS instead of H_FILES.
2001-01-222001-01-22 Michael Hamel <mhamel@adi.co.nz>Joel Sherrill3-2/+7
* include/rtems.h, src/signalcatch.c: Modifications to make CodeWarrior happy.
2000-12-062000-12-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+4
* src/regiongetinfo.c: Removed unused variable to eliminate warning.
2000-11-302000-11-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-10/+13
* src/msgqsubmit.c: Modified multiprocessing conditional so this would compile with both macros and inlines.
2000-11-302000-11-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+10
* macros/rtems/rtems/sem.inl: Added macro implementation of _Semaphore_Get_interrupt_disable().
2000-10-182000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill5-1/+101
* src/regiongetinfo.c, include/rtems/rtems/region.h, include/rtems/rtems/types.h, src/Makefile.am: Added region_get_information() and information control block. * src/regiongetinfo.c: New file.
2000-09-292000-09-29 Stephan Merker <merker@decrc.abb.de>Joel Sherrill4-3/+21
* include/rtems/rtems/ratemon.h, src/ratemonperiod.c, src/ratemontimeout.c: Add next_length field so period length can be changed by the the sequence period(X), period(not X) with no intervening cancel or expiration.
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill4-3/+9
* optman/Makefile.am, src/Makefile.am: Include compile.am.
2000-08-302000-08-30 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2-38/+11
* taskstart.c: Removed 1st cut at rtems_task_start_main_style. Only committed this so it could be easily revisited as we discussing moving main() to user space from BSP space.
2000-08-302000-08-30 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2-5/+42
* taskstart.c: Added 1st cut at rtems_task_start_main_style.
2000-08-10Adding ChangeLogs.Joel Sherrill1-0/+3
2000-07-06Switched to faster implementation.Joel Sherrill1-25/+20
2000-07-06Modfied to execute faster and have fewer instructions.Joel Sherrill1-38/+38
2000-07-06Switched to using isr disable version of _Objects_Get. When theJoel Sherrill1-13/+15
semaphore/mutex can be obtained immediately, this cuts execution time by 50%.
2000-07-06Added _Semaphore_Get_interrupt_disable.Joel Sherrill1-0/+10
2000-07-06Cleaned up to avoid disruptive use of inline conditionals.Joel Sherrill1-18/+16
2000-06-16Patch from John Cotton <john.cotton@nrc.ca> to correct style ofJoel Sherrill1-16/+16
names to be rtems_PACKAGE_method.
2000-06-14Added include of options.h since it was not being picked upJoel Sherrill1-0/+1
by the network build.
2000-06-13New file.Joel Sherrill1-0/+137
2000-06-13Moved i386 and m68k cache management code to libcpu. EverythingJoel Sherrill4-393/+2
now is an implementation of the prototypes in rtems/rtems/cache.h. The libcpu/i386/wrapup directory is no longer needed. The PowerPC needs this done to it.
2000-06-12Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine GauthierJoel Sherrill4-4/+396
<charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860
2000-06-12Merged from 4.5.0-beta3aJoel Sherrill13-62/+56
2000-04-13Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill12-0/+24
2000-02-08Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-2/+1
that contains: * Removes remaining (now illegal) references to $(SRC) from a couple of Makefile.ams * Removes duplicate AC_CONFIG_SUBDIRS macro from c/configure.in * Moves ENABLE_LIBCDIR into RTEMS_PROG_C[C|XX]_FOR_TARGET (hides LIBCDIR from most configure scripts, i.e. LIBCDIR becomes less visible) * Adds RTEMS_PROG_C[C|XX]_FOR_TARGET and RTEMS_CANONICALIZE_TOOLS to libbsp/*/configure.ins (A minor bug in previous implementations, which only has an impact when switching to GNU/Cygnus canonicalization) * Cleans up several bogus comments. * Removes MKLIB * Switches the version number to 4.5.0 (for testing version number handling)
