BSP as we transition to more .o's and less .rel's.
reduce the size of executables.
Here's a tiny patch that shreds memory returned to the pool (such as by
free() and delete). This may help people find some nasty
bugs, so here it is.
wrapped by calls to _Thread_Enable_dispatch and _Thread_Disable_dispatch.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
are:
it work.
when building the executive source.
via the user api.
task to be deleted was created via the same API (i.e. were of the object
class created by this API). For example, a POSIX thread calling
the rtems_task_delete(SELF) directive would incorrectly update the RTEMS
object local pointer table.
Jennifer discovered this when moving tests implemented in C using the
Classic RTEMS API into a tree of Ada tests. The Ada tests were implicitly
using POSIX services. This lead to some unexpected behavior.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
but which did not have real bodies. This is necessary for languages
like Ada95 which must have real entries in a library for bindings.
software floating point emulation code. Code implemented by
Karen Sara Looney <Karen.Looney@colorado.edu> with much
email assistance from Joel.
