task to be deleted was created via the same API (i.e. were of the object
class created by this API). For example, a POSIX thread calling
the rtems_task_delete(SELF) directive would incorrectly update the RTEMS
object local pointer table.
Jennifer discovered this when moving tests implemented in C using the
Classic RTEMS API into a tree of Ada tests. The Ada tests were implicitly
using POSIX services. This lead to some unexpected behavior.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
but which did not have real bodies. This is necessary for languages
like Ada95 which must have real entries in a library for bindings.
software floating point emulation code. Code implemented by
Karen Sara Looney <Karen.Looney@colorado.edu> with much
email assistance from Joel.
directive.
be resolved.
argument indicates whether the task is to be placed at the head or tail of
its priority fifo when it is lowering its own priority. POSIX normally
follows the RTEMS API conventions but GNAT expects that all lowering of
a task's priority by the task itself will result in being placed at the
head of the priority FIFO. Normally, this would only occur as the result
of lose of inherited priority.
The RTEMS API always puts tasks at the end of their priority group except
upon loss of inherited priority.
he received using the Microtec C++ compiler. Most of these are
either missing casts from/to (void *), heavy handed use of enumerated
types, or simply assumed conversions. There is at least one actual
bug in an error path in thread.c in which the wrong argument was
passed to _Thread_Stack_Free and was not being caught by gcc.
MP_packet_Classes
in the core to support multiple algorithms to handle cpu time budgetting
which resulted in a change to the calling sequence of _Thread_Initialize.
Handler could timestamp the starting and stopping of timers. Since
TOD is built on top of Watchdog, this avoided a circular dependency.
create POSIX initialization threads.
sem.c: modified to eliminate Purify warnings
support.h: updated to use RTEMS_APPLICATION macro
in each thread which must be set when the post switch extension is to be run.
