* | MPCI Receive became a thread and the prototype changed. | Joel Sherrill | 1996-02-21 | 1 | -1/+3 | |
* | changed post task extension from user set to api set and added flag | Joel Sherrill | 1996-02-13 | 2 | -4/+9 | |
| | | | | in each thread which must be set when the post switch extension is to be run. | |||||
* | comment added to describe synchronization logic in timeout routine | Joel Sherrill | 1996-02-13 | 1 | -0/+21 | |
* | new isr synchronization algorithm using a single enumerated set of states. | Joel Sherrill | 1996-02-09 | 5 | -14/+31 | |
* | added rtems_interrupt_is_in_progress | Joel Sherrill | 1996-02-09 | 2 | -0/+28 | |
* | changed synchronization algorithm to be a single list of enumerated states | Joel Sherrill | 1996-02-08 | 2 | -4/+4 | |
* | added class to initial id macro | Joel Sherrill | 1996-01-17 | 2 | -8/+8 | |
* | updates from Tony Bennett for PA and UNIX ports | Joel Sherrill | 1996-01-15 | 2 | -2/+14 | |
* | added correct use of _Thread_queue_Enter_critical_section | Joel Sherrill | 1995-12-08 | 1 | -1/+1 | |
* | new states added and _Rate_monotonic_Set_State removed. | Joel Sherrill | 1995-12-05 | 3 | -111/+67 | |
* | Insert mode argument to _Watchdog_Insert removed. Now are watchdog timers | Joel Sherrill | 1995-12-01 | 5 | -21/+18 | |
| | | | | are automatically activated upon insertion. | |||||
* | Changed code for exit from synchronization state to a switch on the | Joel Sherrill | 1995-12-01 | 1 | -11/+19 | |
| | | | | | possible synchronization actions. This should have made it harder to avoid a case. | |||||
* | spurious blank line removed | Joel Sherrill | 1995-12-01 | 2 | -2/+0 | |
* | Replaced critical section algorithm to correct race conditions. | Joel Sherrill | 1995-12-01 | 1 | -10/+19 | |
* | Made _Event_Sync volatile | Joel Sherrill | 1995-12-01 | 2 | -4/+30 | |
| | | | | | | Replaced critical section algorithm to correct race conditions. This resulted in the new variable _Event_Sync_state and the type _Event_Sync_states. | |||||
* | typos fixed | Joel Sherrill | 1995-10-31 | 2 | -1/+3 | |
* | SPARC port passes all tests | Joel Sherrill | 1995-10-30 | 1 | -0/+202 | |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 82 | -271/+271 | |
* | More file movement required api extension to be added to score | Joel Sherrill | 1995-09-21 | 1 | -5/+5 | |
* | More file movement | Joel Sherrill | 1995-09-21 | 4 | -4/+4 | |
* | More file movement | Joel Sherrill | 1995-09-21 | 5 | -6/+3 | |
* | moving files around | Joel Sherrill | 1995-09-21 | 2 | -2/+2 | |
* | Minor bug fixes to get all targets compilable and running. The | Joel Sherrill | 1995-09-19 | 12 | -1075/+361 | |
| | | | | | | single biggest changes were the expansion of the workspace size macro to include other types of objects and the increase in the minimum stack size for most CPUs. | |||||
* | The word "RTEMS" almost completely removed from the core. | Joel Sherrill | 1995-09-11 | 118 | -1687/+2691 | |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API. | |||||
* | Added unused priority ceiling parameter to rtems_semaphore_create. | Joel Sherrill | 1995-08-28 | 37 | -241/+368 | |
| | | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core. | |||||
* | Moved _Thread_Information -> _RTEMS_tasks_Information. | Joel Sherrill | 1995-08-23 | 16 | -23/+97 | |
| | | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it. | |||||
* | Support for variable length names added to Object Handler. This supports | Joel Sherrill | 1995-08-23 | 65 | -239/+735 | |
| | | | | | | both fixed length "raw" names and strings from the API's point of view. Both inline and macro implementations were tested. | |||||
* | fix broken RCS Ids -- $ accidentally lost merging changes earlier | Joel Sherrill | 1995-08-22 | 14 | -14/+14 | |
* | make inline and macro implementations match | Joel Sherrill | 1995-08-22 | 3 | -25/+37 | |
* | make inline and macro implementations match | Joel Sherrill | 1995-08-22 | 4 | -36/+34 | |
* | + Added object type field to object id. | Joel Sherrill | 1995-08-18 | 9 | -2/+9 | |
| | | | | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. + Added parameter "object class" to calls to Initialize Information | |||||
* | Numerous miscellaneous features incorporated from Tony Bennett | Joel Sherrill | 1995-08-17 | 11 | -159/+157 | |
| | | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables | |||||
* | variable length messages | Joel Sherrill | 1995-08-17 | 2 | -119/+269 | |
* | Id reinserted | Joel Sherrill | 1995-08-17 | 2 | -2/+2 | |
* | no limit removed | Joel Sherrill | 1995-08-17 | 2 | -8/+6 | |
* | bug fixes to make macro implementations work | Joel Sherrill | 1995-08-16 | 14 | -26/+26 | |
* | Split out event manager support function | Joel Sherrill | 1995-08-04 | 1 | -20/+0 | |
* | split out event support functions in anticipation of making a handler | Joel Sherrill | 1995-08-04 | 1 | -191/+0 | |
* | deleted unused code | Joel Sherrill | 1995-08-01 | 1 | -38/+0 | |
* | Switched to events for mp receive server and eliminated the special | Joel Sherrill | 1995-07-31 | 1 | -18/+49 | |
| | | | | blocking mechanism for it. | |||||
* | Fully tested on all in-house targets | Joel Sherrill | 1995-05-24 | 2 | -10/+4 | |
* | Initial revision | Joel Sherrill | 1995-05-11 | 146 | -0/+23058 | |
