* macros/Makefile.am: Replace INLINES w/ MACROS (Fix stupid typo in
previous patch).
* include/rtems/rtems/Makefile.am: Remove.
* inline/rtems/rtems/Makefile.am: Remove.
* macros/rtems/rtems/Makefile.am: Remove.
* macros: Handle subdirs, require automake-1.5.
* include/rtems/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* inline/rtems/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* macros/rtems/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/tasks.c: Dereference pointer passed to destructor.
* inline/rtems/rtems/attr.inl: Correct typo and use correct
attribute RTEMS_SYSTEM_TASK. Reported by Chris Johns <ccj@acm.org>.
* src/msgqsubmit.c: Add a comment indicating that we do not have
to account for possibly blocking during the core send operation
because Classic API message queue send is always non-blocking.
* src/msgqsubmit.c: Unblocking message queue operations should
by Suvrat Gupta <suvrat@utstar.com>.
* src/eventsurrender.c: Clear event condition when task is unblocked.
This makes sure that subsequent event send thinks the task is still
blocked and overwrites the initial events received.
* include/Makefile.am, include/rtems/rtems/Makefile.am,
inline/rtems/rtems/Makefile.am, macros/rtems/rtems/Makefile.am,
rtems/optman/Makefile.am:
* include/rtems.h, src/signalcatch.c: Modifications to make
CodeWarrior happy.
* src/regiongetinfo.c: Removed unused variable to eliminate warning.
* src/msgqsubmit.c: Modified multiprocessing conditional so
this would compile with both macros and inlines.
* macros/rtems/rtems/sem.inl: Added macro implementation of
_Semaphore_Get_interrupt_disable().
* src/regiongetinfo.c, include/rtems/rtems/region.h,
include/rtems/rtems/types.h, src/Makefile.am: Added
region_get_information() and information control block.
* src/regiongetinfo.c: New file.
* include/rtems/rtems/ratemon.h, src/ratemonperiod.c,
src/ratemontimeout.c: Add next_length field so period length
can be changed by the the sequence period(X), period(not X)
with no intervening cancel or expiration.
* optman/Makefile.am, src/Makefile.am: Include compile.am.
* taskstart.c: Removed 1st cut at rtems_task_start_main_style.
Only committed this so it could be easily revisited as we
discussing moving main() to user space from BSP space.
* taskstart.c: Added 1st cut at rtems_task_start_main_style.
semaphore/mutex can be obtained immediately, this cuts execution time
by 50%.
names to be rtems_PACKAGE_method.
by the network build.
significant things:
and PowerPC
same code base.
that contains:
* Removes MKLIB
handling)
<andrew@pogo.wv.tek.com>.
Eric Norum <eric@cls.usask.ca>.
I'd like to propose a change to RTEMS task variables that I think would
make them more useful. I think that it is early enough in their
existence to still make changes to their API.
1) Change type from `int' to `void *'.
2) Add extra argument to task_variable_add -- if non-NULL, a pointer to
a `destructor' function to be called when the task exits. This function
would be called with that task's value of the task variable as its
argument. In many cases, the `dtor' function could be `free'.
rtems_status_code rtems_task_variable_add (
rtems_id tid, void **ptr, void (*dtor)(void *));
rtems_status_code rtems_task_variable_delete (rtems_id tid, void **ptr);
This would be all we'd need to cleanly and efficiently support C++
per-thread exception information without dragging in all that POSIX API
stuff.
were done by Joel.
which fixes a nasty dependency bug in optman/Makefile.am. Those
directories have been build twice before, i.e. re-running make after
having built rtems before, was rebuilding the files in optman/
directories.
patch -p1 < rtems-rc-19991203-6.diff
./bootstrap
and his EPICS porting effort.
<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
Addtional major bugs:
* the PACKHEX etc problem
* prevents the *.rels being removed inside the build-tree
* a typo which only shows for when MP is activated
* Alters some custom/*cfg files
