in each thread which must be set when the post switch extension is to be run.
are automatically activated upon insertion.
possible synchronization actions. This should have made it harder to
avoid a case.
like signal dispatching.
correct Information block.
+ Added name pointer to Object_Control.
+ Modified Object Open and Close to address name field.
+ Removed name as separate element from Thread and Proxy Control.
+ Added parameter "object class" to calls to Initialize Information
blocking mechanism for it.
