path: root/c/src/exec/rtems/src/rtclock.c (follow)
* Split Clock Manager into one routine per file.Joel Sherrill1999-05-171-129/+1
* changed _TOD_Is_set from a function to a boolean variableJoel Sherrill1996-09-061-3/+3
* renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the WatchdogJoel Sherrill1996-05-311-1/+1
| | | | | Handler could timestamp the starting and stopping of timers. Since TOD is built on top of Watchdog, this avoided a circular dependency.
* posix support initially addedJoel Sherrill1995-09-261-4/+4
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-23/+21
* Initial revisionJoel Sherrill1995-05-111-0/+153
