path: root/c/src/exec/rtems/src/ratemon.c (follow)
* Split Rate Monotonic Manager into one routine per file.Joel Sherrill1999-05-171-416/+0
* Added --disable-multiprocessing flag and modified a lot of files to makeJoel Sherrill1998-11-231-9/+18
| | | | it work.
* Corrected by adding check for NULL address passed into get_statusJoel Sherrill1997-04-251-0/+3
| | | | directive.
* added support for statistics on rate monotonic periods.Joel Sherrill1997-04-091-5/+78
* new states added and _Rate_monotonic_Set_State removed.Joel Sherrill1995-12-051-77/+53
* Insert mode argument to _Watchdog_Insert removed. Now are watchdog timersJoel Sherrill1995-12-011-4/+2
| | | | are automatically activated upon insertion.
* posix support initially addedJoel Sherrill1995-09-261-3/+3
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-29/+34
* Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1995-08-231-1/+2
| | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-10/+13
* + Added object type field to object id.Joel Sherrill1995-08-181-0/+1
| | | | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. + Added parameter "object class" to calls to Initialize Information
* Initial revisionJoel Sherrill1995-05-111-0/+401
