path: root/c/src/exec/rtems/src/dpmem.c (follow)
* Dual-Ported Memory Manager split into one routine per file.Joel Sherrill1999-05-171-236/+0
* Added --disable-multiprocessing flag and modified a lot of files to makeJoel Sherrill1998-11-231-6/+12
| | | | it work.
* posix support initially addedJoel Sherrill1995-09-261-3/+3
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-28/+32
* Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1995-08-231-1/+2
| | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-11/+18
* + Added object type field to object id.Joel Sherrill1995-08-181-0/+1
| | | | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. + Added parameter "object class" to calls to Initialize Information
* Initial revisionJoel Sherrill1995-05-111-0/+268
