path: root/c/src/exec/rtems/optman/no-part.c (follow)
* More file movementJoel Sherrill1995-09-211-1/+0
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-9/+10
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-2/+2
* Initial revisionJoel Sherrill1995-05-111-0/+71
