path: root/c/src/exec/rtems/optman/no-mp.c (follow)
* modified to generate fatal error when an unconfigured directive is invoked.Joel Sherrill1996-04-191-0/+66
* update to reflect internal threads reorganizationJoel Sherrill1996-03-211-0/+22
* MPCI Receive became a thread and the prototype changed.Joel Sherrill1996-02-211-1/+3
* posix support initially addedJoel Sherrill1995-09-261-10/+10
* More file movementJoel Sherrill1995-09-211-2/+3
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-31/+40
* Initial revisionJoel Sherrill1995-05-111-0/+101
