path: root/c/src/exec/rtems/macros/rtems/rtems/status.inl (follow)
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-8/+0
* Initial revisionJoel Sherrill1995-05-111-0/+47
