* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE" | Joel Sherrill | 1996-07-03 | 1 | -2/+2 |
* | Removed prototyes for static inline routines and moved the comments into | Joel Sherrill | 1996-03-06 | 1 | -0/+7 |
| | | | | | | | | | | | | | | | the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana. | ||||
* | Support for variable length names added to Object Handler. This supports | Joel Sherrill | 1995-08-23 | 1 | -0/+54 |
both fixed length "raw" names and strings from the API's point of view. Both inline and macro implementations were tested. |
