path: root/c/src/exec/rtems/inline/rtems/rtems/region.inl (unfollow)
2002-07-22Remove, moved to cpukit.Ralf Corsepius1-126/+0
2002-07-012002-07-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* Mega patch merge to change the format of the object IDs to loosen the dependency between the SCORE and the various APIs. There was considerable work to simplify the object name management and it appears that the name_table field is no longer needed. This patch also includes the addition of the internal mutex which is currently only used to protect some types of allocation and deallocation. This significantly can reduce context switch latency under certain circumstances. In particular, some heap/region operations were O(n) and had dispatching disabled. This should help enormously. With this merge, the patch is not as clean as it should be. In particular, the documentation has not been modified to reflect the new object ID layout, the IDs in the test screens are not updated, and _Objects_Get_information needs to be a real routine not inlined. As part of this patch a lot of MP code for thread/proxy blocking was made conditional and cleaned up. * include/rtems.h, inline/rtems/rtems/region.inl, macros/rtems/rtems/region.inl, src/dpmem.c, src/dpmemcreate.c, src/msg.c, src/msgqcreate.c, src/part.c, src/partcreate.c, src/ratemon.c, src/ratemoncreate.c, src/region.c, src/regioncreate.c, src/regiondelete.c, src/regionextend.c, src/regiongetinfo.c, src/regiongetsegment.c, src/regiongetsegmentsize.c, src/regionident.c, src/regionreturnsegment.c, src/rtemstimer.c, src/sem.c, src/semcreate.c, src/taskcreate.c, src/taskident.c, src/tasks.c, src/timercreate.c: Modified as part of above.
1999-11-17Updated copyright notice.Joel Sherrill1-2/+1
1998-02-17updated copyright to 1998Joel Sherrill1-1/+1
1997-10-08Fixed typo in the pointer to the license terms.Joel Sherrill1-2/+2
1997-04-22headers updated to reflect new style copyright notice as partJoel Sherrill1-5/+5
1996-07-03switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE"Joel Sherrill1-6/+6
1996-03-06Removed prototyes for static inline routines and moved the comments intoJoel Sherrill1-0/+26
the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana.
