path: root/c/src/exec/rtems/inline/rtems/rtems/message.inl (follow)
* posix support initially addedJoel Sherrill1995-09-261-1/+1
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-95/+0
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-1/+1
* make inline and macro implementations matchJoel Sherrill1995-08-221-4/+3
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-171-18/+19
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* Initial revisionJoel Sherrill1995-05-111-0/+160
