path: root/c/src/exec/rtems/inline/options.inl (unfollow)
1998-12-15Part II automake reorg by Ralf CorsepiusJoel Sherrill1-55/+0
1998-02-17updated copyright to 1998Joel Sherrill1-1/+1
1997-10-08Fixed typo in the pointer to the license terms.Joel Sherrill1-2/+2
1997-04-22headers updated to reflect new style copyright notice as partJoel Sherrill1-5/+5
1996-07-03switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE"Joel Sherrill1-2/+2
1996-03-06Removed prototyes for static inline routines and moved the comments intoJoel Sherrill1-0/+8
the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana.
