path: root/c/src/exec/rtems/include (follow)
* event.h: _Event_Manager_initialization no longer a static inlineJoel Sherrill1996-04-192-0/+12
| | | | support.h: updated to use RTEMS_APPLICATION macro
* Removed prototyes for static inline routines and moved the comments intoJoel Sherrill1996-03-0617-1031/+46
| | | | | | | | | | | | | | | the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana.
* added rtems_interrupt_is_in_progressJoel Sherrill1996-02-091-0/+14
* changed synchronization algorithm to be a single list of enumerated statesJoel Sherrill1996-02-081-2/+2
* added class to initial id macroJoel Sherrill1996-01-171-4/+4
* updates from Tony Bennett for PA and UNIX portsJoel Sherrill1996-01-151-1/+7
* new states added and _Rate_monotonic_Set_State removed.Joel Sherrill1995-12-051-17/+7
* spurious blank line removedJoel Sherrill1995-12-011-1/+0
* Made _Event_Sync volatileJoel Sherrill1995-12-011-2/+15
| | | | | | Replaced critical section algorithm to correct race conditions. This resulted in the new variable _Event_Sync_state and the type _Event_Sync_states.
* posix support initially addedJoel Sherrill1995-09-2622-61/+61
* moving files aroundJoel Sherrill1995-09-211-1/+1
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-192-169/+50
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-1130-220/+587
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-287-32/+62
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1995-08-231-0/+19
| | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-2318-69/+191
* fix broken RCS Ids -- $ accidentally lost merging changes earlierJoel Sherrill1995-08-227-7/+7
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-172-35/+52
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* Id reinsertedJoel Sherrill1995-08-171-1/+1
* no limit removedJoel Sherrill1995-08-171-4/+3
* bug fixes to make macro implementations workJoel Sherrill1995-08-167-13/+13
* Initial revisionJoel Sherrill1995-05-1127-0/+5007
