* Per PR126, configuration structures now match docs.
* include/rtems/rtems/config.h: Use public data types.
* Per PR147 addressed problems when reseting and inserting a timer
into a timer chain that did not honor time passage since the last
time the timer server was scheduled and the new insertion.
* include/rtems/rtems/timer.h, src/timerreset.c, src/timerserver.c,
src/timerserverfireafter.c, src/timerserverfirewhen.c: Broke up
the "reset server" routine into a set of very specific routines
that allowed the server to be unscheduled, timer chains to be
"synchronized" with the current time before inserting a new timer.
* include/rtems/rtems/timer.h: Missed merging these modifications
in previous merge of new timer functionality.
* include/rtems/rtems/timer.h, src/timerserver.c: Add priority
argument to rtems_timer_initiate_server().
* Added task-based timers to the Timer Manager. This added three
new directives:
- rtems_timer_initiate_server
- rtems_timer_server_fire_after
- rtems_timer_server_fire_when
In the process of doing this, a number of cleanups were made.
* src/timerserver.c, src/timerserverfireafter.c,
src/timerserverfirewhen.c: New files.
* include/timer/timer.h: Added new prototypes and supporting types.
* inline/rtems/rtems/timer.h, macros/rtems/rtems/timer.h: Enhanced
_Timer_Is_interval_class() to cover the class TIMER_INTERVAL_ON_TASK.
* src/Makefile.am: Accounted for new files.
* src/rtemstimer.c: Added initialization of _Timer_Server variable.
* src/timercancel.c, src/timerreset.c: Account for addition
of timer classes. Also corrected the headers.
* src/timercreate.c, src/timerdelete.c, src/timerfireafter.c,
src/timerfireafter.c, src/timerident.c: Corrected header.
* include/rtems/rtems/Makefile.am: Remove.
* inline/rtems/rtems/Makefile.am: Remove.
* macros/rtems/rtems/Makefile.am: Remove.
* macros: Handle subdirs, require automake-1.5.
* include/rtems/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* inline/rtems/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* macros/rtems/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/Makefile.am, include/rtems/rtems/Makefile.am,
inline/rtems/rtems/Makefile.am, macros/rtems/rtems/Makefile.am,
rtems/optman/Makefile.am:
* src/regiongetinfo.c, include/rtems/rtems/region.h,
include/rtems/rtems/types.h, src/Makefile.am: Added
region_get_information() and information control block.
* src/regiongetinfo.c: New file.
* include/rtems/rtems/ratemon.h, src/ratemonperiod.c,
src/ratemontimeout.c: Add next_length field so period length
can be changed by the the sequence period(X), period(not X)
with no intervening cancel or expiration.
* optman/Makefile.am, src/Makefile.am: Include compile.am.
names to be rtems_PACKAGE_method.
significant things:
and PowerPC
same code base.
I'd like to propose a change to RTEMS task variables that I think would
make them more useful. I think that it is early enough in their
existence to still make changes to their API.
1) Change type from `int' to `void *'.
2) Add extra argument to task_variable_add -- if non-NULL, a pointer to
a `destructor' function to be called when the task exits. This function
would be called with that task's value of the task variable as its
argument. In many cases, the `dtor' function could be `free'.
rtems_status_code rtems_task_variable_add (
rtems_id tid, void **ptr, void (*dtor)(void *));
rtems_status_code rtems_task_variable_delete (rtems_id tid, void **ptr);
This would be all we'd need to cleanly and efficiently support C++
per-thread exception information without dragging in all that POSIX API
stuff.
and his EPICS porting effort.
Addtional major bugs:
* the PACKHEX etc problem
* prevents the *.rels being removed inside the build-tree
* a typo which only shows for when MP is activated
* Alters some custom/*cfg files
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
RTEMS API extension to avoid problems when the extension is freed.
Eventually the task variable switch extension should become part
of the core context switch and the Ada tcb self implemented in
terms of it.
it is now typedef'ed.
just "rtems_task_variable_t".
task_variables field to API extension, and two directives
(rtems_task_variable_add and rtems_task_variable_delete).
Eric Norum.
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
it work.
via the user api.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
