subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
software floating point emulation code. Code implemented by
Karen Sara Looney <Karen.Looney@colorado.edu> with much
email assistance from Joel.
be resolved.
he received using the Microtec C++ compiler. Most of these are
either missing casts from/to (void *), heavy handed use of enumerated
types, or simply assumed conversions. There is at least one actual
bug in an error path in thread.c in which the wrong argument was
passed to _Thread_Stack_Free and was not being caught by gcc.
support.h: updated to use RTEMS_APPLICATION macro
Replaced critical section algorithm to correct race conditions.
This resulted in the new variable _Event_Sync_state and the type
_Event_Sync_states.
like signal dispatching.
correct Information block.
+ variable length messages
+ named devices
+ debug monitor
