path: root/c/src/exec/rtems/headers/dpmem.h (follow)
* split the inclusion of "EXTERN" data based on whether it was sapi,Joel Sherrill1996-05-281-1/+1
| | | | score, rtems api, or posix api related.
* Removed prototyes for static inline routines and moved the comments intoJoel Sherrill1996-03-061-55/+2
| | | | | | | | | | | | | | | the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana.
* posix support initially addedJoel Sherrill1995-09-261-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-3/+2
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-2/+3
* Initial revisionJoel Sherrill1995-05-111-0/+210
