* include/rtems/rtems/timer.h: Missed merging these modifications
in previous merge of new timer functionality.
* Fixed bug where resetting a timer that was not at the head
of one of the task timer chains resulted in the Timer Server
task waking up too far in the future.
* Added rtems_timer_get_information() directive to support testing.
* src/timerserver.c, include/rtems/rtems/timer.h,
* src/timergetinfo.c: New file.
* src/Makefile.am: Modified to reflect above.
* include/rtems/rtems/timer.h, src/timerserver.c: Add priority
argument to rtems_timer_initiate_server().
* include/rtems/system.h: Only include cpuopts.h when building a
multilib configuration. Some ports still need targopts.h but this
small modification lets those ports work non-multilib while
fixing being fixed for multilib.
* Added task-based timers to the Timer Manager. This added three
new directives:
- rtems_timer_initiate_server
- rtems_timer_server_fire_after
- rtems_timer_server_fire_when
In the process of doing this, a number of cleanups were made.
* src/timerserver.c, src/timerserverfireafter.c,
src/timerserverfirewhen.c: New files.
* include/timer/timer.h: Added new prototypes and supporting types.
* inline/rtems/rtems/timer.h, macros/rtems/rtems/timer.h: Enhanced
_Timer_Is_interval_class() to cover the class TIMER_INTERVAL_ON_TASK.
* src/Makefile.am: Accounted for new files.
* src/rtemstimer.c: Added initialization of _Timer_Server variable.
* src/timercancel.c, src/timerreset.c: Account for addition
of timer classes. Also corrected the headers.
* src/timercreate.c, src/timerdelete.c, src/timerfireafter.c,
src/timerfireafter.c, src/timerident.c: Corrected header.
* src/taskmode.c: Ensure the this service does not dispatch before
tasking is enabled at initialization time.
* optman/, optman/.cvsignore, optman/Makefile.am, optman/no-dpmem.c,
optman/no-event.c, optman/no-mp.c, optman/no-msg.c, optman/no-part.c,
optman/no-region.c, optman/no-rtmon.c, optman/no-sem.c,
optman/no-signal.c, optman/no-timer.c: Removed entire contents of
optman/ directory since it has been moved.
* src/Makefile.am: Add multilib support.
* optman/Makefile.am: Add multilib support.
* macros/rtems/rtems/asr.nil: Fixed typo.
* macros/Makefile.am: Replace INLINES w/ MACROS (Fix stupid typo in
previous patch).
* include/rtems/rtems/Makefile.am: Remove.
* inline/rtems/rtems/Makefile.am: Remove.
* macros/rtems/rtems/Makefile.am: Remove.
* macros: Handle subdirs, require automake-1.5.
* include/rtems/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* inline/rtems/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* macros/rtems/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* src/tasks.c: Dereference pointer passed to destructor.
* inline/rtems/rtems/attr.inl: Correct typo and use correct
attribute RTEMS_SYSTEM_TASK. Reported by Chris Johns <ccj@acm.org>.
* src/msgqsubmit.c: Add a comment indicating that we do not have
to account for possibly blocking during the core send operation
because Classic API message queue send is always non-blocking.
* src/msgqsubmit.c: Unblocking message queue operations should
by Suvrat Gupta <suvrat@utstar.com>.
* src/eventsurrender.c: Clear event condition when task is unblocked.
This makes sure that subsequent event send thinks the task is still
blocked and overwrites the initial events received.
* include/Makefile.am, include/rtems/rtems/Makefile.am,
inline/rtems/rtems/Makefile.am, macros/rtems/rtems/Makefile.am,
rtems/optman/Makefile.am:
* include/rtems.h, src/signalcatch.c: Modifications to make
CodeWarrior happy.
* src/regiongetinfo.c: Removed unused variable to eliminate warning.
* src/msgqsubmit.c: Modified multiprocessing conditional so
this would compile with both macros and inlines.
* macros/rtems/rtems/sem.inl: Added macro implementation of
_Semaphore_Get_interrupt_disable().
* src/regiongetinfo.c, include/rtems/rtems/region.h,
include/rtems/rtems/types.h, src/Makefile.am: Added
region_get_information() and information control block.
* src/regiongetinfo.c: New file.
* include/rtems/rtems/ratemon.h, src/ratemonperiod.c,
src/ratemontimeout.c: Add next_length field so period length
can be changed by the the sequence period(X), period(not X)
with no intervening cancel or expiration.
* optman/Makefile.am, src/Makefile.am: Include compile.am.
* taskstart.c: Removed 1st cut at rtems_task_start_main_style.
Only committed this so it could be easily revisited as we
discussing moving main() to user space from BSP space.
* taskstart.c: Added 1st cut at rtems_task_start_main_style.
