Makefile.in's to Makefile.am's.
support for return codes from POSIX threads that do an implicit exit
by returning from the bottom of the main function.
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
dependencies of "Makefile".
--enable-maintainer-mode.
<rdasilva@connecttel.com> who encountered random failures in his
port of omniORB2.
wrapped by calls to _Thread_Enable_dispatch and _Thread_Disable_dispatch.
of POSIX Init thread to be user configured.
Jiri Gaisler caught this and submitted a patch but a subsequent patch
backed it out accidentally.
future.
cd <rtems-source-tree>
Added multiprocessing conditional.
had not yet been debugged.
installed.
--enable-tests problem a better way.
included and we ended up with undefined references.
and _POSIX_signals_Set_process_signals was done twice.
routines.
There seems to be an ugly dependency between posix-headers and
libcsupport.
Configuring rtems with
../rtems-rc-19990324-0/configure \
--target=i386-rtems \
--prefix=<somewhere> \
--disable-posix
"make RTEMS_BSP=pc386" results into:
/opt/rtems/bin/i386-rtems-gcc --pipe
-B/users/rtems/src/multi/build/pc386/lib/ -specs bsp_specs -qrtems
-I/users/rtems/src/multi/build/pc386/lib/include/networking -g -Wall
-ansi -fasm -O4 -fomit-frame-pointer -c -o o-pc386/utime.o
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c
In file included from
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:16:
/opt/rtems/i386-rtems/include/utime.h:4: sys/utime.h: No such file or
directory
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:24: warning:
`struct utimbuf' declared inside parameter list
its scope is only this definition or declaration,
which is probably not what you want.
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c: In function
`utime':
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:34:
dereferencing pointer to incomplete type
make[4]: *** [o-pc386/utime.o] Error 1
make[3]: *** [all] Error 1
make[2]: *** [all] Error 1
make[1]: *** [all] Error 1
make[1]: Leaving directory `/lfs/poseidon/users/rtems/src/multi/build/c'
make: *** [all] Error 1
Apparently sys/utime.h is one of the posix headers and therefore gets
not installed (I suppose this is correct).
IMO, this probably indicates that sys/utime.h has to be moved to another
include subdirectory and should not be part of the posix-package.
[AFAIK, sys/*.h are system dependent headers, so why should it be a
posix-header? - Hmm]
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
object code that has to be loaded just for initializing the signal
manager.
and eliminate a link error.
split into multiple files.
directory in preparation for automake:
Here is a shell script which reorganizes some parts of the exec/posix
source tree.
This shell scripts moves include files below exec/posix to different
locations than now. It doesn't yet apply automake, but still use the old
autoconf configuration scheme. It doesn't influence the build scheme at
all (unless I corrupted something), only the location of the header
files is different, which would ease applying automake later.
The purpose of this shell script is to demonstrate the style of
structural changes I would like to see in rtems in near future to
prepare a smooth transition to automake. Then CC could pickup rtems'
header files from their location inside of the source tree in future,
instead of the build tree as it is done now.
In case you would accept this patch/script, there would be more similiar
ones to come.
