* | sporadic server debugged and working. This required minor changes in all | Joel Sherrill | 1996-08-07 | 1 | -20/+40 |
| | | | | sporadic server related routines. | ||||
* | _POSIX_Mutex_From_core_mutex_status: added priority ceiling violation case | Mark Johannes | 1996-08-07 | 1 | -0/+2 |
* | _POSIX_Threads_Delete_extension: reorder to eliminate use of local pointer | Joel Sherrill | 1996-08-06 | 1 | -6/+9 |
| | | | | | | variable before set. pthread_join: using local variable so user can pass NULL pointer as argument | ||||
* | POSIX_Mutex_Default_attributes: changed prio_ceiling to maximum priority | Mark Johannes | 1996-08-06 | 1 | -1/+2 |
* | pthread_getspecific: use local variable so references to tcb are completed | Joel Sherrill | 1996-08-06 | 1 | -1/+6 |
| | | | | before enabling dispatching | ||||
* | added page delimiters for comment blocks | Joel Sherrill | 1996-08-01 | 2 | -11/+25 |
* | Fixed default vectors initialization, sigaction which had a redundant | Mark Johannes | 1996-07-15 | 1 | -42/+64 |
| | | | | if clause for DFT action. | ||||
* | basic test cases passed | Joel Sherrill | 1996-07-04 | 1 | -4/+35 |
* | *** empty log message *** | Joel Sherrill | 1996-07-02 | 1 | -1/+22 |
* | initial modifications to support sigtimedwait. | Joel Sherrill | 1996-06-15 | 1 | -9/+30 |
* | sigtimedwait passes initial test cases of timeout and simple satisfaction. | Mark Johannes | 1996-06-13 | 1 | -1/+5 |
* | added queued signals and cleaned up setting of process wide signals so | Joel Sherrill | 1996-06-13 | 1 | -68/+148 |
| | | | | it occurs in only one place. | ||||
* | basic test cases for kill() and alarm(). | Joel Sherrill | 1996-06-13 | 2 | -11/+63 |
| | | | | | kill() in particular needs more test cases for full coverage. The search for a thread interested in this signal has a lot of paths. | ||||
* | basic kill() which send a signal to pthread_self() appears to work. | Joel Sherrill | 1996-06-12 | 1 | -7/+18 |
* | initial implementation of blocking signal routines -- sigwait, sigwaitinfo, | Joel Sherrill | 1996-06-12 | 1 | -34/+227 |
| | | | | sigtimedwait, sigsuspend, and pause. | ||||
* | added comment to make sure we add unblock of thread | Joel Sherrill | 1996-06-11 | 1 | -0/+2 |
* | first attempt at adding algorithm to select the thread which will | Joel Sherrill | 1996-06-11 | 2 | -23/+255 |
| | | | | receive a process-directed signal. | ||||
* | tested blocking a signal, sending it to self, then unblocking it. | Joel Sherrill | 1996-06-11 | 2 | -32/+61 |
| | | | | | make minimum stack size for posix threads double that of the cpu's minimum requirement. | ||||
* | Basic signal functionality appears to work. pthread_kill() can successfully | Joel Sherrill | 1996-06-11 | 3 | -9/+31 |
| | | | | | | | send signals to the current thread or to another blocked thread. nanosleep() can be interrupted by a signal and return the time remaining. Post switch extension added to dispatch posix signal handlers. | ||||
* | first attempt at the routine which vectors signals. | Joel Sherrill | 1996-06-10 | 2 | -12/+328 |
* | changed code which set errno and then returned -1 to use the macro | Joel Sherrill | 1996-06-07 | 5 | -56/+32 |
| | | | | set_errno_and_return_minus_one. | ||||
* | key destructor is now run at correct point in pthread_exit() sequence and | Joel Sherrill | 1996-06-07 | 3 | -104/+173 |
| | | | | | | | | should be correct for other apis as well. missing page numbers added on some references. initial attempt at sig_procmask() and pthread_sigmask(). | ||||
* | Removed assert's from routines which return the error ENOSYS. | Joel Sherrill | 1996-06-06 | 1 | -12/+0 |
* | process oriented scheduler routines now return ENOSYS | Joel Sherrill | 1996-06-06 | 1 | -4/+8 |
* | removed timer_getoverrun() since it was also in ptimer.c | Joel Sherrill | 1996-06-06 | 1 | -11/+0 |
* | Made the implementation of pthread_equal conditional on RTEMS_DEBUG. If | Joel Sherrill | 1996-06-06 | 1 | -0/+10 |
| | | | | | RTEMS is built for debug, then every possible effort is made to validate the two ids. Otherwise, a simple comparison is performed. | ||||
* | completed pthread_setschedparam. | Joel Sherrill | 1996-06-06 | 1 | -73/+130 |
* | added Sporadic Server support | Joel Sherrill | 1996-06-06 | 1 | -27/+109 |
* | renamed Schedule to schedparam in the posix api control information. | Joel Sherrill | 1996-06-05 | 1 | -11/+22 |
| | | | | reviewed the interpretation of most of the thread attributes. | ||||
* | make PTHREAD_SCOPE_SYSTEM an unsupported value for contentionscope. | Joel Sherrill | 1996-06-04 | 1 | -2/+11 |
* | made sure _Thread_Enable_dispatch is not invoked in cases | Joel Sherrill | 1996-06-04 | 1 | -5/+0 |
| | | | | where _Objects_Get failed | ||||
* | made sure routines which called _Objects_Get also called | Joel Sherrill | 1996-06-04 | 1 | -10/+25 |
| | | | | _Thread_Enable_dispatch. | ||||
* | added some of the required functionality to pthread_setschedparam and | Joel Sherrill | 1996-06-04 | 1 | -31/+71 |
| | | | | pthread_getschedparam. | ||||
* | clean up pass | Joel Sherrill | 1996-06-04 | 1 | -10/+14 |
* | renamed the local variable attrp to the_attr in pthread_create | Joel Sherrill | 1996-06-04 | 1 | -11/+11 |
* | changed sched_rr_get_interval to use the interval to timespec routine. | Joel Sherrill | 1996-06-04 | 1 | -3/+2 |
* | added interpretation of scheduling policy and parameter information to | Joel Sherrill | 1996-06-04 | 3 | -28/+98 |
| | | | | | | | | pthread_create initial implementation of get/set id routines better argument checking on scheduler functions. | ||||
* | added thread queue for list of threads waiting to join. | Joel Sherrill | 1996-06-03 | 1 | -9/+33 |
| | | | | | | thread is added to join list in pthread_join. all threads waiting on the join list are flushed when the thread exits. | ||||
* | deleted POSIX threads typedef masking Thread_Control | Joel Sherrill | 1996-06-03 | 2 | -7/+80 |
| | | | | added initial version of pthread_detach and pthread_join | ||||
* | nanosleep now fills in the time remaining structure. | Joel Sherrill | 1996-06-03 | 1 | -4/+3 |
* | renamed _POSIX_Time_Spec_to_interval to _POSIX_Timespec_to_interval | Joel Sherrill | 1996-06-03 | 6 | -20/+41 |
* | created ptimer.c and moved the timer_* routines out of time.c into ptimer.c | Joel Sherrill | 1996-06-03 | 2 | -58/+76 |
* | renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the Watchdog | Joel Sherrill | 1996-05-31 | 3 | -2/+3 |
| | | | | | Handler could timestamp the starting and stopping of timers. Since TOD is built on top of Watchdog, this avoided a circular dependency. | ||||
* | added checks to validate values passed to set attribute routines | Joel Sherrill | 1996-05-31 | 6 | -26/+105 |
* | moved sleep() from psignal.c to unistd.c | Joel Sherrill | 1996-05-31 | 4 | -26/+115 |
| | | | | | | | implemented sigemptyset() sigfillset(), sigaddset(), sigdelset(), and sigismember(). added checks for valid attribute values to some of the pthread_attr_t sets. | ||||
* | First cut at implementing time, clock_gettime, clock_settime, clock_getres, | Joel Sherrill | 1996-05-30 | 2 | -17/+168 |
| | | | | | sleep, and nanosleep. Does not yet support per process clock, per thread clock, interruptible sleep (sleep/nanosleep), or time remaining on nanosleep. | ||||
* | posix initialization threads table was misnamed "posix initialization | Joel Sherrill | 1996-05-29 | 1 | -23/+24 |
| | | | | tasks table" | ||||
* | comment clean up | Joel Sherrill | 1996-05-29 | 15 | -30/+19 |
* | types.c: spacing | Joel Sherrill | 1996-05-29 | 2 | -28/+33 |
| | | | | | psignal.c: kill recognizes SIGABRT and exits to prevent asserts from recursively occurring because kill was not implemented and asserted. | ||||
* | added pthread_exit | Joel Sherrill | 1996-05-29 | 1 | -8/+45 |
| | | | | first posix thread ran |
