internal symbols are supposed to have leading underscores.
should NEVER occur.
to initialize the pthread cancellation fields. This is a patch to
_POSIX_Threads_Create_extension that fixes the problem.
support for return codes from POSIX threads that do an implicit exit
by returning from the bottom of the main function.
dependencies of "Makefile".
--enable-maintainer-mode.
<rdasilva@connecttel.com> who encountered random failures in his
port of omniORB2.
wrapped by calls to _Thread_Enable_dispatch and _Thread_Disable_dispatch.
of POSIX Init thread to be user configured.
Jiri Gaisler caught this and submitted a patch but a subsequent patch
backed it out accidentally.
future.
cd <rtems-source-tree>
Added multiprocessing conditional.
had not yet been debugged.
--enable-tests problem a better way.
included and we ended up with undefined references.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
