* | added checks to validate values passed to set attribute routines | Joel Sherrill | 1996-05-31 | 1 | -1/+2 |
* | comment clean up | Joel Sherrill | 1996-05-29 | 1 | -2/+1 |
* | types.c: spacing | Joel Sherrill | 1996-05-29 | 1 | -28/+29 |
| | | | | | psignal.c: kill recognizes SIGABRT and exits to prevent asserts from recursively occurring because kill was not implemented and asserted. | ||||
* | removed all ifdef's on NOT_IMPLEMENTED. | Joel Sherrill | 1996-05-29 | 1 | -7/+9 |
* | renamed signal.c to psignal.c to avoid naming problems. | Joel Sherrill | 1996-05-29 | 1 | -0/+25 |
| | | | | | | added mp stubs to cond.c and mutex.c to eliminate link errors. added pthread_exit to pthread.c | ||||
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 1 | -0/+2 |
| | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. | ||||
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 1 | -0/+1 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 1 | -0/+167 |
