path: root/c/src/exec/posix/src/semgetvalue.c (unfollow)
2002-07-22Remove, moved to cpukit.Ralf Corsepius1-50/+0
2002-01-042002-01-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-2/+2
* src/clockgetres.c: Apply rtems_set_errno_and_return_minus_one. * src/clockgettime.c: Apply rtems_set_errno_and_return_minus_one. * src/clocksettime.c: Apply rtems_set_errno_and_return_minus_one. * src/killinfo.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueueclose.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuecreatesupp.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuegetattr.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuenotify.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueueopen.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuerecvsupp.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuesendsupp.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuesetattr.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueueunlink.c: Apply rtems_set_errno_and_return_minus_one. * src/nanosleep.c: Apply rtems_set_errno_and_return_minus_one. * src/pthreadkill.c: Apply rtems_set_errno_and_return_minus_one. * src/pthreadsigmask.c: Apply rtems_set_errno_and_return_minus_one. * src/ptimer1.c: Apply rtems_set_errno_and_return_minus_one. * src/sched.c: Apply rtems_set_errno_and_return_minus_one. * src/semaphorecreatesupp.c: Apply rtems_set_errno_and_return_minus_one. * src/semaphorewaitsupp.c: Apply rtems_set_errno_and_return_minus_one. * src/semclose.c: Apply rtems_set_errno_and_return_minus_one. * src/semdestroy.c: Apply rtems_set_errno_and_return_minus_one. * src/semgetvalue.c: Apply rtems_set_errno_and_return_minus_one. * src/seminit.c: Apply rtems_set_errno_and_return_minus_one. * src/semopen.c: Apply rtems_set_errno_and_return_minus_one. * src/sempost.c: Apply rtems_set_errno_and_return_minus_one. * src/semunlink.c: Apply rtems_set_errno_and_return_minus_one. * src/setpgid.c: Apply rtems_set_errno_and_return_minus_one. * src/setsid.c: Apply rtems_set_errno_and_return_minus_one. * src/sigaction.c: Apply rtems_set_errno_and_return_minus_one. * src/sigaddset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigdelset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigemptyset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigfillset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigismember.c: Apply rtems_set_errno_and_return_minus_one. * src/sigpending.c: Apply rtems_set_errno_and_return_minus_one. * src/sigtimedwait.c: Apply rtems_set_errno_and_return_minus_one. * src/utsname.c: Apply rtems_set_errno_and_return_minus_one.
2001-01-242001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
* configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
2000-08-302000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs.
1999-11-02Split the POSIX semaphore manager into multiple files.Joel Sherrill1-0/+46
