2002-07-22 | Remove, moved to cpukit. | Ralf Corsepius | 1 | -102/+0 | |
2001-01-24 | 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support. | |||||
2000-08-15 | 2000-08-15 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -2/+2 | |
* src/ptimer1.c: Removed unused routine PRINT_ERRNO_S. * src/ptimer1.c: Removed unnecessary routine COPY_ITIMERSPEC_S and used structure copy instead. * src/ptimer1.c: Renamed timer_alive_t to POSIX_Timer_Control. * include/rtems/posix/timer.h: Ditto. | |||||
1999-11-02 | Final tuning required to drop out POSIX timers. | Joel Sherrill | 1 | -1/+32 | |
1999-11-02 | *** empty log message *** | Joel Sherrill | 1 | -921/+6 | |
1999-10-21 | Fixed core dump caused when output parameter (otimer) was NULL. | Joel Sherrill | 1 | -3/+7 | |
1999-04-12 | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to correct the | Joel Sherrill | 1 | -0/+2 | |
--enable-tests problem a better way. | |||||
1999-04-12 | Added line to initialize timer_max. | Joel Sherrill | 1 | -0/+2 | |
1999-02-03 | POSIX Timers submitted by Juan Zamorano Flores | Joel Sherrill | 1 | -8/+907 | |
<jzamora@avellano.datsi.fi.upm.es>. | |||||
1996-06-03 | created ptimer.c and moved the timer_* routines out of time.c into ptimer.c | Joel Sherrill | 1 | -0/+75 | |
