path: root/c/src/exec/posix/src/pthreadattrgetinheritsched.c (unfollow)
2002-07-22Remove, moved to cpukit.Ralf Corsepius1-32/+0
2001-01-242001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+3
* configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
1999-11-17Updated copyright notice.Joel Sherrill1-2/+1
1999-01-25Split most of POSIX Threads Manager into multiple files.Joel Sherrill1-13/+10
1998-11-23Added base version of file system infrastructure. This includes a majorJoel Sherrill1-7/+14
1998-05-22Added tcdrain(), cfgetospeed(0, cfsetospeed(), cfgetispeed(), andJoel Sherrill1-0/+26
cfsetispeed().
