* include/Makefile.am: Updated to reflect files merged into newlib.
This resulted in some definitions moving to other files and thus
some secondary effects in RTEMS source code.
* include/unistd.h: Removed. Now use newlib's.
* include/rtems/posix/mqueue.h: Add include of <signal.h>.
* include/rtems/posix/threadsup.h: Add include of <sys/signal.h>
* src/execv.c: Corrected prototype to agree with newlib.
* src/execve.c: Corrected prototype to agree with newlib.
* src/execvp.c: Corrected prototype to agree with newlib.
* src/psignal.c: Rewrote reference to <siginfo.h> in comment since
that file no longer exists.
* src/pthreadkill.c: Added include of <signal.h>.
* src/sigaction.c: Added include of <signal.h>.
* src/sigtimedwait.c: Rewrote reference to <siginfo.h> in comment since
all APIs.
Jiri Gaisler caught this and submitted a patch but a subsequent patch
backed it out accidentally.
--enable-tests problem a better way.
object code that has to be loaded just for initializing the signal
manager.
PROBLEMS
can/will be fixed.
1) Socket timeout field changed from `short' to `long'. This makes longer
timeouts possible. With a 1 kHz system clock the old system allowed
timeouts only up to a little over 30 seconds! This change is a
slightly cleaned-up version of the patch proposed by Ian Lance Taylor.
2) Major changes to BOOTP/DHCP reply handling. Now supports much of
RFC2132. These changes were done at the request of, and with the
assistance of, Erik Ivanenko.
If you're making changes, you might want to change the network
supplement Essentially just do a global search and replace of BOOTP
with BOOTP/DHCP.
so confdefs.h could see it.
to made signals sent to a particular thread from an ISR operated correctly.
This behavior was required by the exception detection/reporting code
in the gnat runtime.
parameters. Also changed returns to macro of -1 and errno set.
_POSIX_signals_Get_highest: changed initial starting signal to SIGHUP, still needs SIGFIRSTNOTRT
if clause for DFT action.
it occurs in only one place.
kill() in particular needs more test cases for full coverage. The search
for a thread interested in this signal has a lot of paths.
sigtimedwait, sigsuspend, and pause.
receive a process-directed signal.
make minimum stack size for posix threads double that of the cpu's minimum
requirement.
send signals to the current thread or to another blocked thread. nanosleep()
can be interrupted by a signal and return the time remaining.
Post switch extension added to dispatch posix signal handlers.
should be correct for other apis as well.
missing page numbers added on some references.
initial attempt at sig_procmask() and pthread_sigmask().
implemented sigemptyset() sigfillset(), sigaddset(), sigdelset(), and
sigismember().
added checks for valid attribute values to some of the pthread_attr_t sets.
sleep, and nanosleep. Does not yet support per process clock, per thread
clock, interruptible sleep (sleep/nanosleep), or time remaining on nanosleep.
psignal.c: kill recognizes SIGABRT and exits to prevent asserts from
recursively occurring because kill was not implemented and asserted.
of the POSIX API necessary to support the GNAT runtime to initially compile.
We now have verified that the specifications for the necessary routines
are correct per the POSIX standards we have.
are automatically activated upon insertion.
