* | 2000-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-08-30 | 1 | -1/+1 |
| | | | | | | * Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs. | ||||
* | Split mqueue.c into a variety of files. | Joel Sherrill | 1999-11-02 | 1 | -672/+0 |
* | Added name to id support routine. | Joel Sherrill | 1999-11-01 | 1 | -0/+15 |
* | Now compiles and is included in normal build even though it is untested. | Joel Sherrill | 1999-04-15 | 1 | -35/+39 |
| | | | | Added multiprocessing conditional. | ||||
* | changed code which set errno and then returned -1 to use the macro | Joel Sherrill | 1996-06-07 | 1 | -10/+6 |
| | | | | set_errno_and_return_minus_one. | ||||
* | renamed _POSIX_Time_Spec_to_interval to _POSIX_Timespec_to_interval | Joel Sherrill | 1996-06-03 | 1 | -2/+2 |
* | comment clean up | Joel Sherrill | 1996-05-29 | 1 | -2/+1 |
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 1 | -1/+1 |
| | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. | ||||
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 1 | -0/+2 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 1 | -0/+713 |
