* | Split condition variables into multiple files. | Joel Sherrill | 1999-11-02 | 1 | -482/+0 |
* | Added --disable-multiprocessing flag and modified a lot of files to make | Joel Sherrill | 1998-11-23 | 1 | -6/+29 |
| | | | | it work. | ||||
* | Added _Thread_Enable_dispatch to already_timedout path on Wait_support. | Joel Sherrill | 1997-10-06 | 1 | -2/+3 |
* | Added commit to indicate exepcted _Thread_Dispatch_disable_level. Hopefully | Joel Sherrill | 1997-03-08 | 1 | -0/+4 |
| | | | | no one will ever get confused here again and try to enable dispatching. :( | ||||
* | Corrected implementation of timed wait on condition variables. First | Joel Sherrill | 1996-09-17 | 1 | -29/+52 |
| | | | | | | | | the timeout is given as a wall-time not an interval as was previously implemented. Second, the interpretation of ETIMEDOUT behavior was incorrect as all possible error cases needed to be checked before this error was returned. This caused problems when the wall-time specified was in the past. | ||||
* | check that we were passed a valid mutex and ignore errors from the | Joel Sherrill | 1996-08-27 | 1 | -0/+8 |
| | | | | | later pthread_mutex_lock. This makes our behavior more compatible with that of FSU pthreads. | ||||
* | pthread_cond_timedwait: added error cases for abstime | Mark Johannes | 1996-08-14 | 1 | -0/+11 |
* | pthread_cond_destroy: added enable dispatch to EBUSY case | Mark Johannes | 1996-08-13 | 1 | -1/+3 |
* | pthread_codn_destroy: EBUSY case moved and uses Thread_queue_First | Mark Johannes | 1996-08-13 | 1 | -3/+3 |
* | pthread_cond_destroy: EBUSY case now uses Thread_queue_First | Mark Johannes | 1996-08-13 | 1 | -1/+1 |
* | _POSIX_Condition_variables_Wait_support: changed status of lock and unlock ↵ | Mark Johannes | 1996-08-13 | 1 | -2/+2 |
| | | | | to return EINVAL is there is an error | ||||
* | _POSIX_Condition_variables_Wait_support: fixed the timeout sequence. | Mark Johannes | 1996-08-13 | 1 | -7/+25 |
* | Wait_support: removed the calls to mutex core to posix status codes | Mark Johannes | 1996-08-12 | 1 | -2/+2 |
* | _POSIX_Condition_variables_Wait_support: added ↵ | Mark Johannes | 1996-08-12 | 1 | -4/+5 |
| | | | | _POSIX_Mutex_From_core_mutex_status for the two calls to the mutex manager | ||||
* | _POSIX_Condition_variables_Signal_support: added setting mutex back to NULL | Mark Johannes | 1996-08-12 | 1 | -5/+7 |
| | | | | | | if the queue has been emptied of waiting tasks. _POSIX_Condition_variables_Wait_support: added error check for different mutexesfor the same condition variable. Also added _Thread_queue_Enter_critical_section | ||||
* | renamed _POSIX_Time_Spec_to_interval to _POSIX_Timespec_to_interval | Joel Sherrill | 1996-06-03 | 1 | -1/+1 |
* | added checks to validate values passed to set attribute routines | Joel Sherrill | 1996-05-31 | 1 | -2/+9 |
* | comment clean up | Joel Sherrill | 1996-05-29 | 1 | -2/+1 |
* | renamed signal.c to psignal.c to avoid naming problems. | Joel Sherrill | 1996-05-29 | 1 | -0/+25 |
| | | | | | | added mp stubs to cond.c and mutex.c to eliminate link errors. added pthread_exit to pthread.c | ||||
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 1 | -0/+1 |
| | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. | ||||
* | added correct use of _Thread_queue_Enter_critical_section | Joel Sherrill | 1995-12-08 | 1 | -0/+1 |
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 1 | -0/+1 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 1 | -0/+398 |
