* inline/Makefile.am: Remove AUTOMAKE_OPTIONS.
* macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
* inline/rtems/posix/mutex.inl (_POSIX_Mutex_Get_support): Corrected
name of routine in header.
* include/sys/Makefile.am: Remove.
* include/rtems/posix/Makefile.am: Remove.
* include/Makefile.am: Handle subdirs.
* inline/rtems/posix/Makefile.am: Remove.
* inline/Makefile.am: Handle subdirs.
* macros/rtems/posix/Makefile.am: Remove.
* macros/Makefile.am: Handle subdirs.
* include/sys/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rtems/posix/Makefile.am: Use 'PREINSTALL_FILES ='.
* inline/rtems/posix/Makefile.am: Use 'PREINSTALL_FILES ='.
* macros/rtems/posix/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/Makefile.am, include/rtems/posix/Makefile.am,
include/sys/Makefile.am, inline/rtems/posix/Makefile.am,
* include/rtems/posix/semaphore.h, inline/rtems/posix/semaphore.inl,
src/ptimer1.c, include/rtems/posix/semaphore.h,
inline/rtems/posix/semaphore.inl, src/alarm.c, src/ptimer1.c,
src/semaphorenametoid.c, src/semopen.c, src/semunlink.c:
Modifications to make CodeWarrior happy.
* inline/rtems/posix/mqueue.inl: Removed explicit dependency on abs().
* inline/rtems/posix/timer.inl, include/rtems/posix/timer.h,
inline/rtems/posix/Makefile.am, src/ptimer1.c: Redid the
style of src/ptimer1.c. Continued effort to make the
POSIX Timer implementation match that of other managers.
Added data structures required to use SuperCore Object Handler.
with interrupts disabled.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
of lowest priority with the RTEMS IDLE thread. This was causing the lowest
priority GNAT Ada task to never run.
be resolved.
and how it corresponds to rtems core priority.
added initial version of pthread_detach and pthread_join
