* | added constant for seconds between posix epoch (1970) and rtems epoch (1988). | Joel Sherrill | 1996-06-03 | 1 | -0/+11 | |
| | | | | Formerly this constant was in the file src/time.c. | |||||
* | commented out cancel handlers related items. | Joel Sherrill | 1996-05-31 | 1 | -0/+3 | |
* | moved attribute related constants into the rtems specific sys/types.h | Joel Sherrill | 1996-05-31 | 1 | -13/+0 | |
| | | | | file in newlib. | |||||
* | posix initialization threads table was misnamed "posix initialization | Joel Sherrill | 1996-05-29 | 2 | -14/+14 | |
| | | | | tasks table" | |||||
* | first cut at pthread_create | Joel Sherrill | 1996-05-29 | 1 | -3/+3 | |
* | added entry point for posix initialization threads to the posix initialization | Joel Sherrill | 1996-05-29 | 1 | -2/+8 | |
| | | | | threads table structure | |||||
* | split the inclusion of "EXTERN" data based on whether it was sapi, | Joel Sherrill | 1996-05-28 | 8 | -10/+48 | |
| | | | | score, rtems api, or posix api related. | |||||
* | added initial set of api extension callouts | Joel Sherrill | 1996-05-28 | 2 | -2/+16 | |
* | commented out interrupt support | Joel Sherrill | 1996-05-28 | 1 | -0/+2 | |
* | added maximum keys | Joel Sherrill | 1996-05-28 | 1 | -0/+1 | |
* | added initial posix configuration support | Joel Sherrill | 1996-05-28 | 1 | -0/+51 | |
* | updates to fix typos | Joel Sherrill | 1996-05-24 | 1 | -11/+14 | |
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 3 | -11/+29 | |
| | | | | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. The removed files were moved to newlib as they were duplicates of files already included there. | |||||
* | SPARC port passes all tests | Joel Sherrill | 1995-10-30 | 1 | -2/+1 | |
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 12 | -0/+14 | |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 26 | -0/+3220 | |
