*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
routines.
There seems to be an ugly dependency between posix-headers and
libcsupport.
Configuring rtems with
../rtems-rc-19990324-0/configure \
--target=i386-rtems \
--prefix=<somewhere> \
--disable-posix
"make RTEMS_BSP=pc386" results into:
/opt/rtems/bin/i386-rtems-gcc --pipe
-B/users/rtems/src/multi/build/pc386/lib/ -specs bsp_specs -qrtems
-I/users/rtems/src/multi/build/pc386/lib/include/networking -g -Wall
-ansi -fasm -O4 -fomit-frame-pointer -c -o o-pc386/utime.o
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c
In file included from
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:16:
/opt/rtems/i386-rtems/include/utime.h:4: sys/utime.h: No such file or
directory
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:24: warning:
`struct utimbuf' declared inside parameter list
its scope is only this definition or declaration,
which is probably not what you want.
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c: In function
`utime':
../../../../../rtems-rc-19990324-0/c/src/lib/libc/utime.c:34:
dereferencing pointer to incomplete type
make[4]: *** [o-pc386/utime.o] Error 1
make[3]: *** [all] Error 1
make[2]: *** [all] Error 1
make[1]: *** [all] Error 1
make[1]: Leaving directory `/lfs/poseidon/users/rtems/src/multi/build/c'
make: *** [all] Error 1
Apparently sys/utime.h is one of the posix headers and therefore gets
not installed (I suppose this is correct).
IMO, this probably indicates that sys/utime.h has to be moved to another
include subdirectory and should not be part of the posix-package.
[AFAIK, sys/*.h are system dependent headers, so why should it be a
posix-header? - Hmm]
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
PROBLEMS
can/will be fixed.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
be resolved.
