all APIs.
* inline/rtems/posix/timer.inl, include/rtems/posix/timer.h,
inline/rtems/posix/Makefile.am, src/ptimer1.c: Redid the
style of src/ptimer1.c. Continued effort to make the
POSIX Timer implementation match that of other managers.
Added data structures required to use SuperCore Object Handler.
* src/ptimer1.c: Removed unused routine PRINT_ERRNO_S.
* src/ptimer1.c: Removed unnecessary routine COPY_ITIMERSPEC_S
and used structure copy instead.
* src/ptimer1.c: Renamed timer_alive_t to POSIX_Timer_Control.
* include/rtems/posix/timer.h: Ditto.
were done by Joel.
Addtional major bugs:
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
internal symbols are supposed to have leading underscores.
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
dependencies of "Makefile".
--enable-maintainer-mode.
of POSIX Init thread to be user configured.
future.
cd <rtems-source-tree>
and _POSIX_signals_Set_process_signals was done twice.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
object code that has to be loaded just for initializing the signal
manager.
split into multiple files.
it work.
the system signals.h file.
Moved POSIX_signals_Siginfo_node type definition to this file to allow
confdefs.h to know the size per queued signal.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
