CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
dependencies of "Makefile".
--enable-maintainer-mode.
of POSIX Init thread to be user configured.
future.
cd <rtems-source-tree>
and _POSIX_signals_Set_process_signals was done twice.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
object code that has to be loaded just for initializing the signal
manager.
split into multiple files.
it work.
the system signals.h file.
Moved POSIX_signals_Siginfo_node type definition to this file to allow
confdefs.h to know the size per queued signal.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
Ada interface where entry is a keyword.
of lowest priority with the RTEMS IDLE thread. This was causing the lowest
priority GNAT Ada task to never run.
be resolved.
visible to other files.
condition variable
psignal.h: fixed typo.
and how it corresponds to rtems core priority.
Schedule was renamed schedparam
