* | moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to here so it would be | Joel Sherrill | 1996-09-08 | 1 | -0/+2 |
| | | | | visible to other files. | ||||
* | switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE" | Joel Sherrill | 1996-07-03 | 1 | -4/+4 |
* | deleted POSIX threads typedef masking Thread_Control | Joel Sherrill | 1996-06-03 | 1 | -11/+5 |
* | posix initialization threads table was misnamed "posix initialization | Joel Sherrill | 1996-05-29 | 1 | -7/+7 |
| | | | | tasks table" | ||||
* | first cut at pthread_create | Joel Sherrill | 1996-05-29 | 1 | -3/+3 |
* | split the inclusion of "EXTERN" data based on whether it was sapi, | Joel Sherrill | 1996-05-28 | 1 | -3/+3 |
| | | | | score, rtems api, or posix api related. | ||||
* | added initial set of api extension callouts | Joel Sherrill | 1996-05-28 | 1 | -1/+15 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 1 | -0/+113 |
