AC_CONFIG_AUX_DIR(../../../..).
Remove RTEMS_CANONICAL_HOST.
Use RTEMS_ENV_RTEMSCPU.
Add AC_PROG_RANLIB.
* include/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
ACLOCAL_AMFLAGS = -I ../aclocal.
* src/rpc/PSD.doc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/xdr/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rpcsvc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/PSD.doc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/xdr/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/Makefile.am, src/xdr/Makefile.am: Include compile.am
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
