path: root/c/src/exec/libnetworking (follow)
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-092-1/+5
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-022-1/+5
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-313-0/+14
| | | | | | | | | | * POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * machine/types.h: Added _CLOCKID_T_ and _TIMER_T_ to be in sync with newlib's <machine/types.h>. * rtems/rtems_bsdnet_internal.h: newlib now includes definition of struct itimerval in <sys/time.h>.
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-252-1/+6
* 2000-10-19 Antti P Miettinen <anmietti@trshp.ntc.nokia.com>Joel Sherrill2000-10-193-13/+21
| | | | | | * lib/tftpDriver.c: add comments to handlers struct function pointers. * rtems/rtems_glue.c: move pointer arithmetic to be _after_ pointer has been checked against NULL.
* 2000-10-18 Chris Johns <ccj@acm.org>Joel Sherrill2000-10-181-0/+4
| | | | * pppd/ipxcp.c: Fixed a typo.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-281-0/+6
| | | | | | * rtems_webserver/Makefile.am, rtems_webserver/base64.c, rtems_webserver/base64.c: Renamed base64.c to wbase64.c. * rtems_webserver/sock.c: Added file missed in merger.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-223-9/+22
| | | | | | | | | | * machine/types.h, pppd/pppd.h, rtems/rtems_bsdnet_internal.h, rtems_webserver/webmain.c: machine/types.h should not have included rtems.h. It is now including precisely the least amount of low level, yet portable .h files to get the basic RTEMS types defined. This rippled into other files since rtems_bsdnet_internal.h used machine/types.h to include rtems.h.
* 2000-09-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-061-5/+9
| | | | * ChangeLog: Cleanup.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0511-31/+49
| | | | | | | * kern/Makefile.am, lib/Makefile.am, libc/Makefile.am, net/Makefile.am, netinet/Makefile.am, nfs/Makefile.am, pppd/Makefile.am, rtems/Makefile.am, rtems_servers/Makefile.am, rtems_webserver/Makefile.am, wrapup/Makefile.am: Include compile.am
* 2000-09-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-052-1/+7
| | | | | | * rtems/rtems_syscall.c: Changed from O_NONBLOCK to internal RTEMS_LIBIO_FLAGS_NO_DELAY to avoid O_NONBLOCK/O_NDELAY confusion and to work with the converted flags.
* 2000-09-01 Rosimildo daSilva <rdasilva@connecttel.com>Joel Sherrill2000-09-011-0/+5
| | | | | * emfdb.c: Removed stray semi-colon. Reported on GoAhead mailing lists by Jim Rudnicki <jdrudnicki@yahoo.com>
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-011-0/+12
| | | | | | | | | | | | * Merged version 2.1 of GoAhead webserver. This update was submitted by Antti P Miettinen <antti.p.miettinen@nokia.com>. * NOTES, base64.c, ejIntrn.h, emfdb.c, emfdb.h, md5.h, md5c.c, um.c, um.h: New files. * wbase64.c: Removed. * Makefile.am, asp.c, balloc.c, default.c, ej.h, ejlex.c, ejparse.c, form.c, h.c, handler.c, mime.c, misc.c, ringq.c, rom.c, security.c, socket.c, sym.c, uemf.c, uemf.h, url.c, value.c, webcomp.c, webmain.c, webpage.c, webrom.c, webs.c, webs.h, websuemf.c, wsIntrn.h: Modified.
* 2000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-012-1/+5
| | | | * netinet/tcp_input.c: Spelling corrections.
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-301-0/+4
| | | | * rtems_webserver/license.txt: New file.
* Patch from Eric Norum <eric@cls.usask.ca> to add optional support forJoel Sherrill2000-08-021-3/+47
| | | | | fast mutexes that bypass the API level to directly interface with the SuperCore.
* Changed name of static table versions to avoid conflict.Joel Sherrill2000-07-141-2/+2
* Moved <sys/cdefs.h> to lib/include so non-networking applications couldJoel Sherrill2000-06-151-1/+1
| | | | include <sys/ioctl.h>.
* *** empty log message ***Joel Sherrill2000-06-141-1/+1
* Patch from Chris Johns <cjohns@cybertec.com.au> to enhance networkJoel Sherrill2000-06-142-43/+216
| | | | | | | | | | | | | initialization. This adds an interface which makes it easier to control the BSD stack from user code. The BSD stack initialise uses it. It is a sort of `function' interface for an ifconfig command. I also added support for attaching and removing interfaces. With hot swap PCI comming online support for hot swap PCI will be an important factor in "state of art" RTOS's. This is also part of a general move on my part to allow RTEMS to be configured at runtime by calls rather than table driven at initialisation.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-1219-70/+249
* New files added on 4.5 branch.Joel Sherrill2000-04-282-0/+0
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-1313-0/+37
| | | | adds .cvsignore.
* Patches rtems-rc-20000118-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-0313-20/+363
| | | | | | | | | | | | | | | | | that contains the automake files for libnetworking plus a couple of minor fixes. [Now only one unused/unsupported Makefile.in remains (./c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in).] To apply: patch -p1 < rtems-rc-20000118-7.diff /bin/sh rtems-rc-20000118-7.rm /bin/sh rtems-rc-20000118-7.add ./bootstrap Notes: * I have tested this one by building all BSPs for m68k, powerpc, sh and unix with toolchains built since last weekend. * I did not touch libnetworking's directory layout.
* Patch from Eric Norum <eric@cls.usask.ca> at the request of JakeJoel Sherrill2000-01-211-33/+56
| | | | | | | Janovetz <janovetz@tempest.ece.uiuc.edu> to return a status from network initialization rather than panic'ing. It changes a bunch of rtems_panics to printfs and returns a status from rtems_bsdnet_initialize_network().
* Patch from Eric Norum <eric@cls.usask.ca> to remove warnings.Joel Sherrill2000-01-211-4/+3
* Removed definition of USHRT_MAX to remove lots of redefinition warnings.Joel Sherrill2000-01-101-2/+0
* Patch from Eric Norum <eric@cls.usask.ca> to make the NTP handler a littleJoel Sherrill1999-12-131-1/+1
| | | | more flexible about the error status returned from a timeout.
* Correction from Eric Norum for timeout in TFTP driver following bugJoel Sherrill1999-12-131-2/+3
| | | | | | | | | report by Nick.SIMON@syntegra.bt.co.uk: TFTP uses UDP and UDP packets are prime targets for getting dropped when the network gets busy. I want the number of retries quite large in my application. I see that PACKET_REPLY_MILLISECONDS is, in fact, not being used.
* Removed debugging printfs.Joel Sherrill1999-12-011-2/+0
* Patch from Eric Norum <eric@cls.usask.ca> to fix a spot in the tftp fileJoel Sherrill1999-12-011-1/+0
| | | | | | system table from when the rtems_filesystem_operations_table structure changed and the initializer in libnetworking/lib/tftpDriver.c did not get updated.
* Added missing files from PPP port.Joel Sherrill1999-11-302-0/+297
* Added port of ppp-2.3.5 from Tomasz Domin <dot@comarch.pl> of ComArch SA.Joel Sherrill1999-11-303-3/+187
| | | | | | | | | | Tomasz only tested this on the mpc823. The official site for the original source for this PPP implementation is: ftp://cs.anu.edu.au/pub/software/ppp NOTE: As of 11/30/1999, the current version of this source is 2.3.10.
* Web server uses the POSIX API. Therefor, it must be disabled when theJoel Sherrill1999-11-161-1/+5
| | | | POSIX API is disabled.
* Patch from Eric Norum <eric@cls.usask.ca> which includes:Joel Sherrill1999-11-103-8/+163
| | | | | Patches against 1105 snapshot to add NTP server support to network configuration/BOOTP.
* Patch from Eric Norum <eric@cls.usask.ca> to add NTP BOOTP support becauseJoel Sherrill1999-11-093-1/+48
| | | | | | | | EPICS needs a synchronized time-of-day clock. This patch is the changes needed to get NTP server information from a BOOTP server. This patch also adds NTP server information to the network configuration structure, too.
* Patch from Emmanuel Raguet <raguet@crf.canon.fr> and Eric ValetteJoel Sherrill1999-10-271-1/+2
| | | | | | | | | | <valette@crf.canon.fr> to add a port of the GoAhead web server (httpd) to the RTEMS build tree. They have successfully used this BSP on i386/pc386 and PowerPC/mcp750. Mark and Joel spoke with Nick Berliner <nickb@goahead.com> on 26 Oct 1999 about this port and got verbal approval to include it in RTEMS distributions.
* Patch from Eric Norum <eric@cls.usask.ca> to address the following problemJoel Sherrill1999-10-251-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | report from Philip A. Prindeville <philipp@zembu.com>: I was working on a device driver for a certain ethernet chipset that occassionally wraps in its buffer, and causes a resulting mbuf chain with only a few dozen bytes in the first mbuf of the chain. I wouldn't have thought this would be a problem, until I ran some stress tests that flooded the ethernet receiver with packets and started to get panics here: 250 251 if (m->m_pkthdr.len < sizeof(struct ip)) 252 goto tooshort; 253 254 #ifdef DIAGNOSTIC 255 if (m->m_len < sizeof(struct ip)) 256 panic("ipintr mbuf too short"); 257 #endif 258 259 if (m->m_len < sizeof (struct ip) && 260 (m = m_pullup(m, sizeof (struct ip))) == 0) { 261 ipstat.ips_toosmall++; 262 return; 263 } 264 ip = mtod(m, struct ip *); and the panic was at line 256. But if I #undef'd DIAGNOSTICS, then the m_pullup() at line 260 does the right thing and the packet ends up being processed just fine. So I started wondering, (a) why was the test checking for something that apparently wasn't a fatal condition but rather one that is subsequently recovered from a couple of lines later and (b) why panic as a diagnostic "aid" from a recoverable condition rather than just (say) log a message to the console? All of this seems overly severe for no reason that is readily apparent to me.
* Modified to avoid conflicts on definitions of malloc. newlib 1.8.2Joel Sherrill1999-10-063-3/+3
| | | | | | | | now prototypes the malloc family in stdlib.h. This causes conflicts with the way the network stack overrides the definitions of malloc. As best I (being Joel) can tell, commenting stdlib.h out keeps the files compiling and referencing the desired malloc/free but results in more warnings.
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bugJoel Sherrill1999-10-041-3/+3
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make libnetworkingJoel Sherrill1999-10-041-2/+2
| | | | a top level more independently configured package.
* Patch from Eric Norum <eric@cls.usask.ca>. Comments follow:Joel Sherrill1999-10-042-3/+5
| | | | | | The old system would panic when the loopback interface was included as part of the network initialation structures. With the printf you get an message, but the interface is still properly initialized.
* Applied patch rtems-rc-19990820-6.diff.gz fromJoel Sherrill1999-09-071-0/+24
* Comment cleanup from Eric Norum <eric@cls.usask.ca>.Joel Sherrill1999-08-261-5/+0
* Patch from Eric Norum <eric@cls.usask.ca> to readd the behavior whereJoel Sherrill1999-08-231-30/+6
| | | | the minor number indicated the port number to try.
* Patch from Eric Norum <eric@cls.usask.ca>:Joel Sherrill1999-07-121-20/+15
| | | | | | | | | | | | | | I get the following warning when compiling the latest snapshot. I had a quick look at the source -- it certainly looks to me like this is a real bug. ../../../../src/rtems-19990709/c/src/lib/libc/mount.c:97: warning: `options' might be used uninitialized in this function Also, I changed the TFTP test program and TFTP driver to reflect the changes in the way paths are passed to the TFTP driver. The TFTP driver now needs a proper `dotted-decimal' hostname as the second component of the path name.
* After comments D. V. Henkel-Wallace <gumby@zembu.com>, the interface toJoel Sherrill1999-06-151-1/+1
| | | | mount() was changed to avoid the use of a string as the options.
* Patch from Ian Lance Taylor <ian@airs.com>:Joel Sherrill1999-06-114-2/+64
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | The select function is not particularly efficient when dealing with a large number of sockets. The application has to build a big set of bits and pass it in. RTEMS has to look through all those bits and see what is ready. Then the application has to look through all the bits again. On the other hand, when using RTEMS, the select function is needed exactly when you have a large number of sockets, because that is when it becomes prohibitive to use a separate thread for each socket. I think it would make more sense for RTEMS to support callback functions which could be invoked when there is data available to read from a socket, or when there is space available to write to a socket. Accordingly, I implemented them. This patch adds two new SOL_SOCKET options to setsockopt and getsockopt: SO_SNDWAKEUP and SO_RCVWAKEUP. They take arguments of type struct sockwakeup: struct sockwakeup { void (*sw_pfn) __P((struct socket *, caddr_t)); caddr_t sw_arg; }; They are used to add or remove a function which will be called when something happens for the socket. Getting a callback doesn't imply that a read or write will succeed, but it does imply that it is worth trying. This adds functionality to RTEMS which is somewhat like interrupt driven socket I/O on Unix. After the patch to RTEMS, I have appended a patch to netdemos-19990407/select/test.c to test the new functionality and demonstrate one way it might be used. To run the new test instead of the select test, change doSocket to call echoServer2 instead of echoServer.
* Patch from Eric Norum <eric@cls.usask.ca> to fix bug reported byJoel Sherrill1999-06-111-0/+2
| | | | | | | | | | | | | | | | | | Ian Lance Taylor <ian@airs.com>: Ian Lance Taylor wrote: > > In rtems-19990528, sbwait sets SB_WAIT in sb_flags. sowakeup checks > it. Why doesn't socket_select set it? > > I don't know that this is a bug--I haven't tried to create a test > case. However, it certainly looks odd. > > Ian Yes, there's a bug there. Sorry about that. It was introduced when I did some cleanup on the sleep/wakeup handling in rtems_glue.c.
