path: root/c/src/exec/libnetworking/rtems (follow)
* 2001-09-19 Chris Johns <ccj@acm.org>Joel Sherrill2001-09-193-2/+16
| | | | | | | * nfs/bootp_subr.c, rtems/rtems_bootp.c, rtems/rtems_bsdnet.h, rtems/rtems_bsdnet_internal.h Added support for populating the initial "root" filesystem with information obtained via the DHCP response.
* 2001-09-19 Chris Johns <ccj@acm.org>Joel Sherrill2001-09-192-0/+415
| | | | | | | | | * Added support for populating the initial "root" filesystem with information obtained via the DHCP response. * rootfs: New directory. * rootfs/.cvsignore, rootfs/Makefile.am, rootfs/mkrootfs.c, rootfs/mkrootfs.h: New files. * configure.in, Makefile.am: Modified to reflect addition.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-4/+6
| | | | | | | | | | | * Makefile.am, arpa/Makefile.am, machine/Makefile.am, net/Makefile.am, netinet/Makefile.am, nfs/Makefile.am, rtems/Makefile.am, rtems_servers/Makefile.am, rtems_webserver/Makefile.am, sys/Makefile.am, vm/Makefile.am: Apply include_*HEADERS instead of H_FILES. * include/Makefile.am: Remove. * Makefile.am: Add handling of *.h files. * configure.in: Remove include/Makefile.
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-311-0/+2
| | | | | | | | | | * POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * machine/types.h: Added _CLOCKID_T_ and _TIMER_T_ to be in sync with newlib's <machine/types.h>. * rtems/rtems_bsdnet_internal.h: newlib now includes definition of struct itimerval in <sys/time.h>.
* 2000-10-19 Antti P Miettinen <anmietti@trshp.ntc.nokia.com>Joel Sherrill2000-10-191-1/+1
| | | | | | * lib/tftpDriver.c: add comments to handlers struct function pointers. * rtems/rtems_glue.c: move pointer arithmetic to be _after_ pointer has been checked against NULL.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-221-0/+2
| | | | | | | | | | * machine/types.h, pppd/pppd.h, rtems/rtems_bsdnet_internal.h, rtems_webserver/webmain.c: machine/types.h should not have included rtems.h. It is now including precisely the least amount of low level, yet portable .h files to get the basic RTEMS types defined. This rippled into other files since rtems_bsdnet_internal.h used machine/types.h to include rtems.h.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-5/+7
| | | | | | | * kern/Makefile.am, lib/Makefile.am, libc/Makefile.am, net/Makefile.am, netinet/Makefile.am, nfs/Makefile.am, pppd/Makefile.am, rtems/Makefile.am, rtems_servers/Makefile.am, rtems_webserver/Makefile.am, wrapup/Makefile.am: Include compile.am
* 2000-09-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-051-1/+1
| | | | | | * rtems/rtems_syscall.c: Changed from O_NONBLOCK to internal RTEMS_LIBIO_FLAGS_NO_DELAY to avoid O_NONBLOCK/O_NDELAY confusion and to work with the converted flags.
* Patch from Eric Norum <eric@cls.usask.ca> to add optional support forJoel Sherrill2000-08-021-3/+47
| | | | | fast mutexes that bypass the API level to directly interface with the SuperCore.
* Patch from Chris Johns <cjohns@cybertec.com.au> to enhance networkJoel Sherrill2000-06-142-43/+216
| | | | | | | | | | | | | initialization. This adds an interface which makes it easier to control the BSD stack from user code. The BSD stack initialise uses it. It is a sort of `function' interface for an ifconfig command. I also added support for attaching and removing interfaces. With hot swap PCI comming online support for hot swap PCI will be an important factor in "state of art" RTOS's. This is also part of a general move on my part to allow RTEMS to be configured at runtime by calls rather than table driven at initialisation.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-122-14/+28
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patches rtems-rc-20000118-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-031-0/+41
| | | | | | | | | | | | | | | | | that contains the automake files for libnetworking plus a couple of minor fixes. [Now only one unused/unsupported Makefile.in remains (./c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in).] To apply: patch -p1 < rtems-rc-20000118-7.diff /bin/sh rtems-rc-20000118-7.rm /bin/sh rtems-rc-20000118-7.add ./bootstrap Notes: * I have tested this one by building all BSPs for m68k, powerpc, sh and unix with toolchains built since last weekend. * I did not touch libnetworking's directory layout.
* Patch from Eric Norum <eric@cls.usask.ca> at the request of JakeJoel Sherrill2000-01-211-33/+56
| | | | | | | Janovetz <janovetz@tempest.ece.uiuc.edu> to return a status from network initialization rather than panic'ing. It changes a bunch of rtems_panics to printfs and returns a status from rtems_bsdnet_initialize_network().
* Patch from Eric Norum <eric@cls.usask.ca> to remove warnings.Joel Sherrill2000-01-211-4/+3
* Removed definition of USHRT_MAX to remove lots of redefinition warnings.Joel Sherrill2000-01-101-2/+0
* Patch from Eric Norum <eric@cls.usask.ca> which includes:Joel Sherrill1999-11-101-0/+1
| | | | | Patches against 1105 snapshot to add NTP server support to network configuration/BOOTP.
* Patch from Eric Norum <eric@cls.usask.ca> to add NTP BOOTP support becauseJoel Sherrill1999-11-092-0/+16
| | | | | | | | EPICS needs a synchronized time-of-day clock. This patch is the changes needed to get NTP server information from a BOOTP server. This patch also adds NTP server information to the network configuration structure, too.
* Modified to avoid conflicts on definitions of malloc. newlib 1.8.2Joel Sherrill1999-10-063-3/+3
| | | | | | | | now prototypes the malloc family in stdlib.h. This causes conflicts with the way the network stack overrides the definitions of malloc. As best I (being Joel) can tell, commenting stdlib.h out keeps the files compiling and referencing the desired malloc/free but results in more warnings.
* Patch from Eric Norum <eric@cls.usask.ca>. Comments follow:Joel Sherrill1999-10-042-3/+5
| | | | | | The old system would panic when the loopback interface was included as part of the network initialation structures. With the printf you get an message, but the interface is still properly initialized.
* Comment cleanup from Eric Norum <eric@cls.usask.ca>.Joel Sherrill1999-08-261-5/+0
* Patch from Ian Lance Taylor <ian@airs.com>:Joel Sherrill1999-06-111-0/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | The select function is not particularly efficient when dealing with a large number of sockets. The application has to build a big set of bits and pass it in. RTEMS has to look through all those bits and see what is ready. Then the application has to look through all the bits again. On the other hand, when using RTEMS, the select function is needed exactly when you have a large number of sockets, because that is when it becomes prohibitive to use a separate thread for each socket. I think it would make more sense for RTEMS to support callback functions which could be invoked when there is data available to read from a socket, or when there is space available to write to a socket. Accordingly, I implemented them. This patch adds two new SOL_SOCKET options to setsockopt and getsockopt: SO_SNDWAKEUP and SO_RCVWAKEUP. They take arguments of type struct sockwakeup: struct sockwakeup { void (*sw_pfn) __P((struct socket *, caddr_t)); caddr_t sw_arg; }; They are used to add or remove a function which will be called when something happens for the socket. Getting a callback doesn't imply that a read or write will succeed, but it does imply that it is worth trying. This adds functionality to RTEMS which is somewhat like interrupt driven socket I/O on Unix. After the patch to RTEMS, I have appended a patch to netdemos-19990407/select/test.c to test the new functionality and demonstrate one way it might be used. To run the new test instead of the select test, change doSocket to call echoServer2 instead of echoServer.
* Patch from Eric Norum <eric@cls.usask.ca> to fix bug reported byJoel Sherrill1999-06-111-0/+2
| | | | | | | | | | | | | | | | | | Ian Lance Taylor <ian@airs.com>: Ian Lance Taylor wrote: > > In rtems-19990528, sbwait sets SB_WAIT in sb_flags. sowakeup checks > it. Why doesn't socket_select set it? > > I don't know that this is a bug--I haven't tried to create a test > case. However, it certainly looks odd. > > Ian Yes, there's a bug there. Sorry about that. It was introduced when I did some cleanup on the sleep/wakeup handling in rtems_glue.c.
* Changes from Eric Norum to add a loop and limit on the length of timeJoel Sherrill1999-05-281-22/+32
| | | | the stack will wait for mbufs.
* Alignment corrected per Eric Norum's suggestion.Joel Sherrill1999-05-281-1/+2
* Patch from Eric Norum <eric@pollux.usask.ca> to eliminate a panic when theJoel Sherrill1999-05-271-42/+85
| | | | network stack runs out of mbufs.
* Patch from Eric Norum <eric@cls.usask.ca> to corrent a miscount in lengthJoel Sherrill1999-04-271-1/+1
| | | | that results in an error in parsing network unit names/numbers.
* Changed ioctl() prototype to be more like Linux/POSIX than BSD to easeJoel Sherrill1999-04-191-1/+1
| | | | porting of ACE to RTEMS.
* After discussion with Eric Norum <eric@skatter.usask.ca>,Joel Sherrill1999-04-191-0/+22
| | | | | I added __INSIDE_RTEMS_BSD_TCPIP_STACK__ that trips all the needed macro definitions for a network driver.
* Moved sparc specific version of in_cksum_hdr to an inline routine likeJoel Sherrill1999-04-011-31/+0
| | | | | the reset of the CPU specific implementations after comment from Eric Norum.
* Patch from Eric Norum <eric@skatter.usask.ca> which changed the exitJoel Sherrill1999-03-311-2/+1
| | | | sequence.
* Removed warning for `#ifdef' argument starts with punctuation.Joel Sherrill1999-03-301-1/+1
* Patch to add shutdown() routine from Tony R. Ambardar <tonya@ece.ubc.ca>.Joel Sherrill1999-03-301-0/+25
* SPARC optimized version of IP checksum header routine. SubmittedJoel Sherrill1999-03-231-0/+32
| | | | by Jiri Gaisler <jgais@ws.estec.esa.nl>.
* Patch from Eric Norum <eric@skatter.usask.ca> to improve parsing ofJoel Sherrill1999-03-232-0/+45
| | | | | network interface names. This change does not introduce any compatibility problems.
* Patch from Eric Norum <eric@skatter.usask.ca> that adds externalJoel Sherrill1999-03-191-4/+30
| | | | fcntl support and an external fcntl handler for sockets.
* Patch from Eric Norum <eric@skatter.usask.ca> to eliminate externalJoel Sherrill1999-03-014-23/+35
| | | | | IO handlers scheme that was implemented originally just to support sockets. The file system IO switch is more general and works fine.
* Patch from Eric Norum to correct bug induced by select() patch.Joel Sherrill1999-02-052-5/+11
* Modifed to reflect transition from device driver to file system.Joel Sherrill1999-02-041-41/+4
* Patch from Eric Norum <eric@skatter.usask.ca> to avoid dereferencing aJoel Sherrill1999-01-281-1/+4
| | | | NULL pointer.
* Changed prototype of rtems_bsdnet_makeFdForSocket to (void *) pointerJoel Sherrill1999-01-261-1/+1
| | | | so that the libc code did not have to know about (struct socket).
* Made to compile after hacking tftp driver into beginnings of a mini-filesystem.Joel Sherrill1999-01-213-3/+188
* Merged Eric Norum's select patch that was based on 4.0 and resolvedJoel Sherrill1998-12-102-119/+20
| | | | all conflicts.
* Patch from Ian Lance Taylor <ian@airs.com>:Joel Sherrill1998-12-073-5/+12
| | | | | | | | | | | | | RTEMS permits using the SO_SNDTIMEO and SO_RCVTIMEO socket options to set a timeout for most socket I/O operations. However, in RTEMS 4.0.0, those options do not affect connect or accept. I don't know of any way to put a timeout on those calls in RTEMS 4.0.0; can anybody point to one. Since it is frequently useful to have a timeout on accept, and sometimes useful to have a timeout on connect shorter than the BSD system default of 75 seconds, the following patch causes SO_RCVTIMEO to affect connect and accept.
* Patch from Eric Norum <eric@skatter.usask.ca>:Joel Sherrill1998-11-192-0/+2
| | | | | | | | | | | | | | | 1) Socket timeout field changed from `short' to `long'. This makes longer timeouts possible. With a 1 kHz system clock the old system allowed timeouts only up to a little over 30 seconds! This change is a slightly cleaned-up version of the patch proposed by Ian Lance Taylor. 2) Major changes to BOOTP/DHCP reply handling. Now supports much of RFC2132. These changes were done at the request of, and with the assistance of, Erik Ivanenko. If you're making changes, you might want to change the network supplement Essentially just do a global search and replace of BOOTP with BOOTP/DHCP.
* Added header files per request from Chris Johns to avoid problemsJoel Sherrill1998-10-121-0/+4
| | | | in include file order.
* Patch from Eric Norum <eric@skatter.usask.ca>:Joel Sherrill1998-09-291-3/+2
| | | | | | | | | | | | | | Remember the test to see if a socket could be read and written at the same time by two different tasks? I discovered that if both tasks attempt to close the socket a panic can occur from inside the BSD code. Closing the same socket twice from two different threads is certainly an error, but a panic is not the greatest error reporting method :-) The following small change to the socket close routine should reduce the chances of the panic.
* Patch from Eric Norum <eric@skatter.usask.ca>:Joel Sherrill1998-09-211-29/+101
| | | | | | | Here's a patch to make the rtems_showroute routine a little more useful. For `host' route table entries the link-level address is now displayed. This is equivalent to the old `show arp table' information displayed by the KA9Q code.
* Patch from Eric Norum <eric@skatter.usask.ca> to fix a cryptic errorJoel Sherrill1998-09-101-1/+3
| | | | message after comments from Eric Valette <valette@crf.canon.fr>.
* Fixed spacing. More comments from Eric Norum need to be addressed.Joel Sherrill1998-08-311-7/+7
