path: root/c/src/exec/libnetworking/net/if_pppvar.h (follow)
* 2002-03-27 Ilya Alexeev <ilya@continuum.ru>Joel Sherrill2002-03-271-0/+1
| | | | | | | | | | | | | * PR162 * net/if_ppp.c ppp_txdaemon(), net/if_pppvar.h pppstart(): Local variables must not be used in a device write routines. Now ppp_softc structure have own character for writing to device (sc_outchar). I think that converting local variables to static is not a right solution, because problems will occur in the case of two or more ppp instances. * net/ppp_tty.c pppstart(): Type of the ioffset variable must be u_long, otherwise in the case of the big output packet endless loop may occur.
* 2001-01-31 Mike Siers <mikes@poliac.com>Joel Sherrill2002-01-311-17/+45
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Nice Update of PPPD support which eliminates the requiremetn that drivers be in the termios TASK_DRIVEN mode. Mike did significant testing and reports that it seems to be more stable and handle larger packets better. This patch replaces the termios tasks with more general pppd network driver tasks. The functions pppinput() and pppstart() get called from the interrupt service routine. * Makefile.am, configure.ac, net/Makefile.am, net/bpf.h, net/ethernet.h, net/if.c, net/if.h, net/if_arp.h, net/if_dl.h, net/if_ethersubr.c, net/if_llc.h, net/if_loop.c, net/if_ppp.h, net/if_pppvar.h, net/if_types.h, net/netisr.h, net/ppp-comp.h, net/ppp_defs.h, net/pppcompress.h, net/radix.c, net/radix.h, net/raw_cb.c, net/raw_cb.h, net/raw_usrreq.c, net/route.c, net/route.h, net/rtsock.c, pppd/Makefile.am, pppd/README, pppd/STATUS, pppd/auth.c, pppd/cbcp.c, pppd/ccp.c, pppd/ccp.h, pppd/chap.c, pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c, pppd/ipcp.h, pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h, pppd/magic.c, pppd/magic.h, pppd/options.c, pppd/patchlevel.h, pppd/pathnames.h, pppd/pppd.8, pppd/pppd.h, pppd/rtemsmain.c, pppd/rtemspppd.c, pppd/rtemspppd.h, pppd/sys-rtems.c, pppd/upap.c, pppd/upap.h, pppd/utils.c, pppd/example/README, pppd/example/netconfig.h, wrapup/Makefile.am: Modified. * net/bsd-comp.c, net/if_ppp.c, net/ppp-deflate.c, net/ppp.h, net/ppp_tty.c, net/pppcompress.c, net/zlib.c, net/zlib.h: New file. * modem/, modem/.cvsignore, modem/Makefile.am, modem/ppp.c, modem/ppp.h, modem/ppp_tty.c, modem/pppcompress.c: Subdirectory removed.
* 2000-11-25 Antti P Miettinen <antti.p.miettinen@nokia.com>Joel Sherrill2000-11-251-0/+111
* wrapup/Makefile.am: Added modem subdir. * configure.in, Makefile.am: Added modem subdir. * net/Makefile.am: Added if_pppvar.h, pppcompress.h. * pppd/Makefile.am: Added pppmain.c (which needs work). * pppd/chat.c, pppd/fsm.c, pppd/fsm.h, pppd/ipxcp.c, pppd/main.c, pppd/ppp_tty.c, pppd/upap.c: Changes from Thomas Doerfler <Thomas.Doerfler@imd-systems.de> and cosmetic changes by me. Actually main.c and ppp_tty.c should be scratched. The modem subdir has the real ppp_tty.c and the real pppd main is in pppmain.c.
