path: root/c/src/exec/libnetworking/machine (follow)
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-271-1/+1
| | | | | | | | | | | | | | | * machine/Makefile.am: Use 'PREINSTALL_FILES ='. * net/Makefile.am: Use 'PREINSTALL_FILES ='. * netinet/Makefile.am: Use 'PREINSTALL_FILES ='. * vm/Makefile.am: Use 'PREINSTALL_FILES ='. * pppd/Makefile.am: Use 'PREINSTALL_FILES ='. * sys/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems_servers/Makefile.am: Use 'PREINSTALL_FILES ='. * arpa/Makefile.am: Use 'PREINSTALL_FILES ='. * nfs/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems_webserver/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems_telnetd/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-4/+4
| | | | | | | | | | | * Makefile.am, arpa/Makefile.am, machine/Makefile.am, net/Makefile.am, netinet/Makefile.am, nfs/Makefile.am, rtems/Makefile.am, rtems_servers/Makefile.am, rtems_webserver/Makefile.am, sys/Makefile.am, vm/Makefile.am: Apply include_*HEADERS instead of H_FILES. * include/Makefile.am: Remove. * Makefile.am: Add handling of *.h files. * configure.in: Remove include/Makefile.
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-311-0/+2
| | | | | | | | | | * POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * machine/types.h: Added _CLOCKID_T_ and _TIMER_T_ to be in sync with newlib's <machine/types.h>. * rtems/rtems_bsdnet_internal.h: newlib now includes definition of struct itimerval in <sys/time.h>.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-221-9/+10
| | | | | | | | | | * machine/types.h, pppd/pppd.h, rtems/rtems_bsdnet_internal.h, rtems_webserver/webmain.c: machine/types.h should not have included rtems.h. It is now including precisely the least amount of low level, yet portable .h files to get the basic RTEMS types defined. This rippled into other files since rtems_bsdnet_internal.h used machine/types.h to include rtems.h.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-3/+16
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patches rtems-rc-20000118-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-031-0/+10
| | | | | | | | | | | | | | | | | that contains the automake files for libnetworking plus a couple of minor fixes. [Now only one unused/unsupported Makefile.in remains (./c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in).] To apply: patch -p1 < rtems-rc-20000118-7.diff /bin/sh rtems-rc-20000118-7.rm /bin/sh rtems-rc-20000118-7.add ./bootstrap Notes: * I have tested this one by building all BSPs for m68k, powerpc, sh and unix with toolchains built since last weekend. * I did not touch libnetworking's directory layout.
* Moved sparc specific version of in_cksum_hdr to an inline routine likeJoel Sherrill1999-04-011-0/+43
| | | | | the reset of the CPU specific implementations after comment from Eric Norum.
* Added PowerPC specific header checksum code.Joel Sherrill1999-02-041-4/+61
| | | | Added volatile to i386 assembly statements in header checksum code.
* Added CVS IdsJoel Sherrill1998-08-208-0/+39
* FreeBSD stack compiles for the first time (except libc/strsep.c).Joel Sherrill1998-08-209-0/+298
