path: root/c/src/exec/libfs (follow)
* Warning removal from D. V. Henkel-Wallace <gumby@zembu.com>.Joel Sherrill1999-06-141-6/+0
* Removed usage of printf.Joel Sherrill1999-05-271-1/+1
* Removed asserts that shouldn't be called and commented case where thisJennifer Averett1999-03-312-3/+2
| | | | indicates an internal error.
* Corrected bug where pointer to doubly linked blocks was being incorrectlyJoel Sherrill1999-03-081-2/+34
| | | | calculated.
* Changed IMFS to use IMFS_NAME_MAX as the maximum length of a basenameJoel Sherrill1999-02-247-23/+29
| | | | | | | rather then NAME_MAX. NAME_MAX is 255 and that lets IMFS chew up memory too fast. Perhaps in the future, the places in IMFS that put a maximum length name string on the stack and the jnode structure does not include a maximu length name string can be fixed so this is not a problem.
* Corrected multiple places the file size was not being properly updated.Joel Sherrill1999-02-101-2/+8
* Corrected spacing and added some new error checks that were neededJoel Sherrill1999-02-051-9/+9
| | | | to avoid dereferencing NULLs.
* Added imfs_fdatasync routine that gets called from both fdatasync and datasync.Jennifer Averett1998-12-031-0/+26
* Added a imfs fdatasync routine that gets called for fdatasync and datasync.Jennifer Averett1998-12-031-0/+4
* Modifications for RTEMS_UNIX.Jennifer Averett1998-12-031-1/+10
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-2326-0/+4268
