path: root/c/src/exec/libfs/src/imfs/memfile.c (follow)
* The object memfile.o was being included in the miniIMFS even though itJoel Sherrill1999-11-021-20/+59
| | | | | | | should not have been. This required that IMFS_rmnod be split into three separate (per file type) routines to avoid dependencies. In the end, a miniIMFS application is 6K smaller than one using the full IMFS.
* Added initial cut at miniIMFS which leaves out memfile and directoryJoel Sherrill1999-10-261-0/+20
| | | | | readdir support. The next step is to add a mount table and configure either the miniIMFS or the full IMFS at the application level.
* Corrected bug where pointer to doubly linked blocks was being incorrectlyJoel Sherrill1999-03-081-2/+34
| | | | calculated.
* Corrected multiple places the file size was not being properly updated.Joel Sherrill1999-02-101-2/+8
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+1000
