path: root/c/src/exec/libfs/src/imfs/imfs_load_tar.c (follow)
* 2001-01-12 Jake Janovetz <janovetz@uiuc.edu>Joel Sherrill2001-01-121-13/+49
| | | | | | | | | | | | | | * src/imfs/imfs.h, src/imfs/imfs_creat.c, src/imfs/imfs_debug.c, src/imfs/imfs_eval.c, src/imfs/imfs_fchmod.c, src/imfs/imfs_handlers_memfile.c, src/imfs/imfs_init.c, src/imfs/imfs_initsupp.c, src/imfs/imfs_stat.c, src/imfs/memfile.c, src/imfs/miniimfs_init.c: Final developmental update to "tarfs". When rtems_tarfs_load() is called, it checks the permissions on each file. If there is write permission, it just creates a standard file using "creat()" and therefore, uses the IMFS MEMORY_FILE. If there is no write permission, it creates a LINEAR_FILE node with the appropriate properties. If the permission is ever changed to writeable, IMFS_fchmod converts it to a regular memory file.
* 2000-12-12 Jake Janovetz <janovetz@uiuc.edu>Joel Sherrill2000-12-131-0/+209
* src/imfs/linearfile.c, src/imfs/imfs_load_tar.c: New files. * src/imfs/Makefile.am, src/imfs/imfs.h, src/imfs/imfs_creat.c, src/imfs/imfs_debug.c, src/imfs/imfs_eval.c, src/imfs/imfs_handlers_memfile.c, src/imfs/imfs_init.c, src/imfs/imfs_initsupp.c, src/imfs/imfs_stat.c, src/imfs/miniimfs_init.c: Added "tarfs". This is not really a tar filesystem. It is a way to load a tar image into the IMFS but actually leave bulky file contents in the original tar image. It essentially adds the linear file type and associated support and a loader routine.
